Starrett Automatic Center punch 18C?
94yj
fort worth texas
what is the difference between the a b and c models and which one is best for light to heavy metal indention's tia
Vvmvbb
CT
...I am beginning to believe that even Starrett doesn't know the difference between the 18A and 18AA. Otherwise you'd think they'd tell us, heh?
CWP1616L
USA
I have the 18A and the 18C.
The 18C packs a wallop of a punch; too strong for thin gauge sheet metal. It'll put a dent in thin gauge sheet metal. I use it only on heavy steel plate.
The 18A is what I use for sheet metal and wood. It'll put a mark for your drill bit to locate, but not too deep to leave a deep dimple.
The 18B I've never tried.
rshadd
Doylestown, PA
Vvmvbb
CT
Which hits harder, 18A or 18AA? That's kept secret :)
I'll guess the force scales with size, but I've not seen Starrett literature that actually says that.
Krokodil
South Africa
Just bought a 18c off Amazon for $40. Good deal? Got fed up of he cheap ones breaking after a month. Will report back when I get it.
Carla
MEMBER EMERITUS
You can adjust the force of strike, to some extent, by turning the knorled cap over the spring, down (towards the point) for a stronger strike, up for lighter.
cheers
Carla
Vvmvbb
CT
cheers
Carla
Thanks. Yes, that adjustment works very well on the Starretts. I have the 18B and even on the softest setting it hits too hard for a lot of what I do (plastic) so I want the lowest range, which I'm forced to guess is the 18AA...
