Started putting together my home shop.
Moloko
Allentown PA
Moved into this house last year, finally getting around to setting up my shop. I'm currently renting a barn about 10 miles away, and I'm sick of driving there to work on stuff, and not having tools around the house.
Here is the garage when we moved in.
A few weeks ago we applied Epoxy Coat floor coating. During the spring I also painted the walls a fresh coat of white, and put block sealer half way down the wall because the walls are about 3 feet under ground.
On Sunday we re-did the existing 220 line, and added two 50 amp outlets. One will be for the air compressor, and one for whatever welder or plasma cutter I'm using.
Yesterday I drug over my 1950 Westinghouse Air Brake air compressor. It's 80 gallon, 220 volt, twin stage. Compressor is from an actual train. Its slow to fill, but I run it at 160PSI tank pressure.
The garage was already fully plumbed for shop-air, inside and outside when we moved in. Just have to hook the compressor to the existing lines, and add new fittings (last owners robbed them all, wtf?)
CNGsaves
KS and OK
Wow, fabulous transformation on the concrete shop.
That window unit A/C do the trick since shop likely pretty cool w/ all block construction?? Any insulation in ceiling??
What's the plan for heating in winter??
Keep the pics coming . . . . looking good ! :thumbup:
