Starting a 28X32 with loft. Need advice with water challenges.
Nick D
Hello all,
I have a project underway and before I can spend the time creating a proper thread in the garage gallery I am hoping to get some advice about water around the excavation site. We dug 4' down for the footings and started getting water accumulating about 1/2 through the dig. When finished it was about 4" deep. Let it sit over night, came back in the morning to a hole with 20" of water.
I currently have two 1/3hp sump pumps rated at about 40GPM each relieving the hole of water.
I can see the level going down, but here is my problem. There is clearly water flowing into the hole. Enough that if I turn one of the two pumps off, the level slowly rises again.
3 days ago (day of excavation) we did get 1/2" of rain, but nothing really since. I have heard stories of people coming across underground springs in this town, so it doesn't surprise me that I have this type of water issue.
So lets say I manage to dry it out enough to get the foundation poured, (Footing + Frost Wall) what kind of issues can I expect to have in the future with high volume of water (likely underground spring) flowing next to or perhaps below my footings?
Thanks in advance!
Nick D
blkhonda1991
Connecticut
it seems like your water table is really high if that is what you are getting 3 days after a rain. is a floating slab an option allowed by code where you are?
kbs2244
I belive in saving money and DIY as much as the next guy.
Buy sometimes you have to buy the knowledge and experience of the pros.
At the least I would talk to your building department.
Your tax dollars pay for them.
And they should know about the area around you as well as your lot.
Then have a concrete guy with a good reputation do the work.
A good foundation is an absolute requirment.
You need to do it right even if it puts a dent in the budget and a delay is needed.
N
Nick D
Floating slab is acceptable as long as it has Engineer sign off. Thanks for the tip to contact the Building Department.
I initially contacted a local Engineering Consultant who was more interested in convincing me not to do a floating slab than taking my money. The economy can't be THAT good, can it?! I may have to revisit that option if I can't control the water in the hole, or if the building department has no good information to offer me.
I am fairly sure I can dry the hole out and continue on. I am hoping to get the opinions from GJ members who are confident with foundations. Should extra work (precautions) be done to compensate for what appears to be flowing water and a high water table??
Thanks,
Nick D
78Bird
Charlotte, NC
Any way to dig a drain trench to let it run off and get a good look at where it's coming from?
If you did hit a spring it might be possible to dig down more then plug it with something impermeable or divert the flow.
If it's general water table.... I dunno.
70redbee
Knoxville,Md
You need to dig it down about another 2 feet and fill this with large gravel. Cover the gravel with a geotech fabric.Pour your footings like normal with 2 pcs of rebar. Once the stem wall is built lay draintile around the perimetor of the structure and run to daylight. I have built many houses like this and never had a problem. You just need to get the water away from the building. If not able to daylight just put in a pit with a sump pump. Good luck.
N
Nick D
Thanks to all who have replied.
A small update.
I have managed to get the water level down to less than 2". After speaking with a local builder, I have decided that the issue is a high water table, and that I picked a bad month to dig a hole here.
Here is what I am thinking:
-Dig deep hole in corner (out of the way of footing forms) for sump pump.
-Bring the level up in the base of the hole, about 4-6". This should get me up out of the water.
Yes, this will raise the building up, but I am planning to bring grade up anyway, so another 6" isn't going to spoil things.
I don't think I need to dig deeper and bring more fill in. The base seems very solid. The material is a sand gravel mix with larger stones about the size of a fist.
I am also not sure draintile will improve the situation, especially because I cannot daylight it. If the issue is a high water table, the tile could potentially be submersed from end to end when the rain falls in large amounts and in my mind, that means no flow.
For a little more background, we have never had standing water on the property, no matter how much rain we got.
My question now is can I fill the hole back in with the material I removed, or would a fresh crushed stone of some sort be a much better base? Do both of these materials need a compactor run on them? I am told the vibration may bring the walls of the excavated hole in? Am I way off in thinking that I shouldn't concern myself with draintile?
Thanks again for the advice.
NickD
Creemore, Ont
This is just a follow up post in case anyone in the future happens to be in a similar situation and is looking for options.
I contacted a Engineer who provided a new footing design to compensate for the active and high water table.
The details are:
- Increase width of footing from 20" to 24"
- Increase rebar runs from 2-1/2" to 3-5/8" runs
- Prepare the base with no more than 6" deep of 3/4" Clear stone. Stone must be tampered, also must have geotextile fabric (landscaping material) beneath the stone.
Some pics of the progress.
Thanks Again for the input.
Rosco
South Georgia
looking good. Very smart to come on here and post for suggestions in the middle of the project.......that takes patience!
