Starting compressor with light switch
rmadursk
I am somewhat lazy and occasionally forgetful.
I try to remember to turn off my compressor when I leave the shop to save electricity but I don't always remember to do so. Left unattended/unused the compressor runs about once every 5-6 hours. I could try to elimanate all of the leaks but there are probably 100 joints in the lines plus 8 drops with quick connects. When I installed it every joint was checked with soap for leaks but over time I some must have developed. It only leaks down to about 100 psi. I thought about adjusting the pressure switch but would like to know that if something blows (and I've turned off the lights) the compressor will not run on.
So, I want to only have the compressor running if the lights are on. That way it will only be running when I need it.
If you live in the Clarksburg, WV area and would like to do this for me send me a PM, otherwise I am looking for suggestions, pointers to products, other threads (couldn't find any with a few searches).
Thanks,
Ron
BFBOB
Easy. Hook up the coil of a relay (contactor, motor starter) in parallel with the lights. Connect the N.O. contacts of the relay in series with your compressor switch. Then, the comperssor won't run unless its switch AND the lights are on.
Make sure the relay has a 120 VAC coil, and the contacts are rated to handle your compressor's current.
BFBOB
Here's a schematic to shed some light on the subject:
  • CompRly.pdf
rlitman
Long Island
I've got a whole house style vacuum hanging in my shop for dust collection. To turn it on and off, I have a furnace fan relay, with a 24V transformer powering the coil. I have thin wires that I've taped to the vacuum hoses, with a switch at the end, that controls closes the low voltage circuit on the coil, to turn the vacuum on.
The same thing would work well for a compressor.
So long as you're only starting the motor with this, and you leave the internal pressure switch to do the job of stopping it, this setup should last a really long time.
rsanter
visalia ca
Have the switch feed a relay or contractor and you are set.
Pulling direct through the switch will be very short lived
Bob
