ddawg16
Now that the garage is done...I get to use it....which includes making all the work surfaces that I have wanted....one of which is a metal working table.
I would really like to have the room to have a table like OccupantRJ does....about 6' long, 4' wide...with a 1/4" plate steel top...big *** vise on one end and a ton of storage drawers underneath...
Don't have that much room so I'm thinking a little smaller. I'm building a 24"x24" table....enough to space to mount my 'almost big *** vise' on...and have enough room for the usual jeep stuff (like beating the U-joints out of a ds).
First step is getting a useful surface top...and here it is...
24" x 24" x 1" plate steel.....yes boys, 1" thick...at 40.8 lbs/sq ft, that works out to about 163.2 lbs....just for the top surface. I figure I can beat on that pretty good before it moves....by the time I add the vice, legs, and junk drawer under it...it will be over 200 lbs.
I also plan to add a swing up grate that I can use for welding/cutting.
The only things I'm not sure about yet is how tall...and if I should put wheels on it (metal).
Right now I'm thinking around 30"...that would put the vice up around 36-37".....when I'm using it, I will most likely be beating the **** out of something so it makes sense to put the work surface somewhat level with my elbow.
???? Agree? Disagree?
(I love over-kill, if you've seen my tables posted on here).
