Starting to finish the shop
MushCreek
Upstate South Carolina
After nearly 10 years of on-and-off barn and house building, I'm finally getting around to my domain- the shop. I insulated this wall (there's a staircase behind it), and decided to do a test run of some materials. I put a PT 2X4 on the floor, followed by 4' of galvalume roofing, and then 4' of white pegboard. There's still 4 more feet to go, and I'll use something painted white. I might try 5mm underlayment, as that's about the cheapest thing I can find currently.
The tin is set in J-trim. I like the look, although the bottom will collect all kinds of stuff, especially behind the mill. Oh well; that's what shop vacs are for. I set it on top of a 2X4 because my ceiling is 12' 4". I already had the 4' tin, otherwise I could have gotten it 4" longer.
Doing the rest of the shop is going to be a chore. I have to move (literally) tons of stuff out of the way, insulate, then do the wall coverings.
manwithtools
Lebanon, TN
That screw on the bottom row is in the wrong row of holes...
Other wise it looks like a great start. I too would be worried about the J-Channel catching all kinds of "stuff". Could you bend up a Z-Channel that would let "stuff" fall off?
MushCreek
Good catch on the screws. I was too busy trying to hold the panel up to pay much attention. The Z-trim is an idea. I used J-trim, as the panels are just slid in from the end. There are no fasteners in the panels; just the trim. With Z-trim, I'd put screws in to hold the bottom of the panel. I might do a similar wainscot in the wife's attached garage, so I'm still working out what works best. I've also thought about using PVC 1X4 along the bottom instead of PT.
MushCreek
I don't think the foam strip would hold up to hot chips flying off of the mill. I think going forward, I'll just use a Z-trim, or no bottom trim at all. I'll just have to put screws in wherever there's a stud.
Craig Balzer
Colorado Springs
MushCreek
I have the same metal sheathing on my interior walls.
As you said, you used a wood base board that the metal sheet is resting on.
My installation includes what is called a "rat board" -- I think.
Looks to me your J trim belongs on top -- see attached photo. The "rat board" is attached to my wall in this photo and in the close up in the fore ground.
HTH
Craig
MushCreek
I used J-trim top and bottom to make a track that the metal slides in to- no screws. I realized later that it would be a trash collector, and I may redo it.
