Static from sandblaster
TheClaw
Chicagoland
We are getting a lot of static from our sandblaster while operating it. This is my son, he's standing on a foam HF mat and rubber soled shoes. he gets a little jolt from the screws on the glove rings if his arm gets to close to the box when he's blasting. The vacuum is also running.
It's not alot, but its anoying and static like that with all the fluids in the garage will get us nominated for a Darwin award.
Any suggestions?
larry4406
Northern Virginia
Ground the cabinet....
T
TheClaw
Chicagoland
Cabinet is on rubber feet.
Ok, stupid question #2, before spending money, would a ground from the Cabinet to some nearby conduit be ok?
BrandonV
Arizona
I suspect you have the cabinet grounded one way or another. Usually I see a light, blower, or something that is grounding the cabinet but yes, you can tie the cabinet to anything.
Bonding the gun is going to be the ticket here. If that's out of the budget the anti-static strap bonded to the cabinet is the next cheapest option.
Torque&Recoil
NE Ohio
The electrical outlets that I have installed in metal boxes, automatically ground to the box and hence to the EMT conduit. If your setup is similar, then yes, you can ground the cabinet or gun or whatever to your metal conduit. I suppose there might be some vintage outlets that don't do this, so I can't say for 100% certain that it will work. You do have a 3 wire electrical system, right?
OccupantRJ
Eastern North Carolina
The flow of abrasive and the air extraction flow builds a static load in and on the cabinet. When standing on the mat you are isolated until you get close to the cabinet. A static strap to the cabinet or keeping your body against the cabinet before beginning blasting will usually solve this. Blasting a plastic piece will really light you up. My cabinet size is such that I can keep my chest against it while in use. No issues since I learned to do that.
vwpieces
Hills, PA
I get shocks using my SkatBlast too.
Mine is larger but still metal housing and my arms easily go into the gloves further.
Extended use I get a black and blue like bruise inside my left arm from the shocks.
Never really cared to resolve the issue.
I have added metal electrical boxes on back for a receptacle to power on the lights and Vac at same time. So it is essentially grounded to the electrical system. But I am not.
My dust collector has been modified after the motor on top burned out. 3D printed a hose adapter on top to just use a $30 Hart shop vac now.
The cabinet was free. I did ad the Eastwood gun and foot pedal and found a deal on a filter to replace the rotted original, why the motor burned out...
