stationary vs portable air compressor
sdx
I'm looking into getting my first air compressor. But I have a couple questions I was hoping you guys could answer.
I would like to get 60 gallon stationary air compressor, but I'm concerned how long of an air hose is practical to reach all areas of a house. Say, if I wanted to paint a bedroom, or paint the exterior of my house.
Is that possible with a stationary air compressor? I'd prefer to not have to buy a portable as well as a stationary. Thoughts?
CGT80
IE, SoCal, USA
I ran a conventional spray gun for shooting lacquers and oil based primers and finishes when doing cabinets, trim, or doors and roll up doors. I got out of painting full time, but my uncle (who taught me to paint) ended up setting up a small airless just for clear coatings.
Spraying finishes and getting good results is not a cake walk. It takes years of practice to get really good, even with an airless. You have to mask very well, or have the control with a gun to get very close without overspraying other surfaces, and it is still easy to go too far (such as spraying eves a different color than walls on an exterior).
For other air tools, 3/8" hose will usually work to get around a house. Cordless tools and great corded tools will often work better than air tools. The main tools I use air for, are impact gun, blast cabinet, angle and straight die grinders, blow gun, conventional paint gun. My old 5" milwaukee angle grinder is a beast and a 2 or 3 inch flap wheel on my 90 degree IR composite die grinder is great for small work and blending, but there was a gap for medium work where one was too heavy and the other not aggressive enough. A makita 4" angle grinder filled that gap. The body is small in diameter and it has decent power.
Look for an oil lubed, cast iron compressor, and 2 stage is great for keeping the pressure well above what is needed (smaller single stage can let your pressure drop too much).
For painting interiors, such as ceilings and walls, the right technique with a brush and roller will give you better results than a conventional or airless sprayer and there will be less mess. Most people don't know how to efficiently use a brush or roller so it takes them a long time and it is much harder than it has to be.
Bigger is better in air compressors. What other tools do you plan to use? There are a bunch of threads on the subject, on this forum. You can read for days.
md21722
Mt Juliet, TN
If you are looking at painting, and portable, you should be looking at portables. Jenny/Emglo and Rolair make lines of portable compressors most often used by framers for their nailing guns.
For hard line garage use, a stationary is usually better. That's because most stationary air compressors are built for garage use in mind, with tank, pump and motor size in line with garage use. Many garage type tools use a lot of air, and a 5HP dual stage is the practical minimum.
Die grinders used for any length of time will draw 18-25 CFM continuously. Not really a match for an 8 gallon 1.5-2HP compressor intended for framing use. And nobody really makes a 60 gallon portable.
If you're only buzzing off the remnants of a head gasket with a 3M roloc wheel on the end of a die grinder, a small compressor may work just fine (30-60 gallon) but if you're going to be running it for minutes at a time, you need to go big. For die grinders, disc sanders, and DA's, a 5HP dual stage is the practical minimum with 7.5HP or more preferred.
Just be glad you don't live in a high elevation area like the Colorado Rockies where air compressors are downrated 20% or more because of altitude!
gdocktor3
Connecticut
If I were you I'd buy a 30 gallon on wheels. I have a craftsman 30 gallon 5 hp horizontal on wheels that I bought for that exact purpose. Big enough and powerful enough to run air tools and impact guns, small enough to load in the truck and bring to job sites for running small nail guns, etc.
