Steel Bending Jigs
Paticus
San Francisco Bay Area, CA
Anybody build there own bending jigs? Or maybe some good tips and tricks?
I'm have some 1.5" x 3/16" flat stock steel that I am looking to bend 180 degrees with a 2-2.5" radius.
I planned on using a O/A Torch with rosebud tip for heat
purplezr2
Central MN
I build one to make fancy "L" for a garden arbor I made. I destroyed the fixture to use it for some thing else so I have no pictures. I can post pictures of the L if you like.
Jim Stabe
San Diego, Ca
I made this out of scrap steel to bend plate brackets. It will do 1/4" but at full width 3/16" is about all I can manage.
Something like this works also
lilredex
Toronto
Try something like this. You can make a die to suit. That large one is a 3" pipe section.
Picture shows it upside down. In use, that square tubing is in a vise. And, an appropriate handle slides over that stub.
bimmer1980
York, PA
I also bought the harbor freight bender. For what the OP want to do, it is what I suggest. I mounted mine to a re-inforced pallet. I can move the whole thing around with my forklift and I don't need it bolted to the floor. It comes with plenty of dies. I bent some 1-1/2" x 3/16 or 1/4" bar in about a 170 degree bend on a 1-1/2" die. I was surprised at how easy it was.....
I also bolted my HF shrinker/stretcher to the same pallet. I would probably unbolt the shrinker/stretcher to gain full access to the bender....
carhunter
southern Ohio
There's a old fabricators trick that I saw years ago but never built for myself. Take a heavy steel table and space holes at even distances moving out from the center. You can put bolts or pins in various holes to trap the steel stock and bend it in a desired radius.
I'll try and dig up a picture.
gorilla
Weld a piece of round stock the correct diameter for the radius you desire to a piece of plate. Then weld a stop pin about a material thickness away from the round stock far enough back to hold one side of the hook. Then heat up the stock and bend it around.
lilscorpion
Colorado
I dabbed this to make corner armor for a CJ5 back when I did things caveman.
Welded one end to the plate and then used leverage and a torch to roll the plate. They ended up like the ones you'd buy, couldn't tell a difference.
Vegaman_Dan
Pacific, WA
That's steel bar stock? It looks like aluminum based on the color.
Still, simple jig in a vise works wonders. I don't haev a need to make a jig, but I want to anyways now. :)
