rweaver
I have one of the steel carport type buildings with 2.5 inch square bows with
4'-2" between bows. the building is closed in on concrete and I would like your opinions on insulating. I thought about using 2" foil faced foam sheets 90 degrees to the bows walls and ceiling on lathe boards and putting a way for air to enter @ bottom off walls outside and vents @ peak because there is a small collar tye area @ peak.
