Anyone know of a good steel door that is polyurethane foamed and has solid blocking (wood or engineered wood) in the area of the bores for the deadbolt and knob? I purchased a 3-0 door from my lumber yard which I figured would be much better than anything from a big box store, but pretty disappointed when I put the door hardware on it. You can't even get the deadbolt and handle tight without collapsing the steel on the foam and creating a dish in the door that you can see. You can see a vertical crease line about 1-1/4" from the edge of the door which is obviously all the wider the solid edge of the door is. It also appears there is a flimsy plastic cylinder that is foamed into the door where the bore is to be, which I assume is supposed to give the compressive support to the door for the hardware to tighten against?? It appears when my doors were bored, the cylinder was compromised because a portion of the cylinder is cut away. I'm not even convinced if the cylinder was fully in place it would work well, just seems like junk! I am planning to take up the quality issue with the lumberyard, but I'm fully ready for them to claim I'm overtightening the hardware... BS. This wasn't a cheap door from an expense, it was $700 pre-hung in a maintenance free jamb. Just appears the door is poorly designed, and cheaply made.
