f150skidoo
So one of my coworkers asked me to build him a steel fire pit. I asked him to give me a drawing with dimensions to build to but he said build it to what ever I want as long as its around 3'-4' wide. So Its 39" square, 20" tall and is made of 3/16" steel. Using my press brake I bent a 1.5" lip around the top edge to prevent possible distortion from the heat of fires. I drilled eight 1/2" holes for water drainage and is used for air also, I bent up some steel into a C channel to prevent hot embers from dropping to the ground but its still open for water and air to pass through.
