i can only read 6 or 7 replies
im a pipefitter, metaltub.
iron pipe is preferred for air service.
i saw, you prefer usa manufacture.
not available at diy or local hardware stores.
you'll have to visit a piping supply house.
black pipe suitable for your needs is 'schedule 40' wall thickness
fittings are 150# wog rated.
unions, i'd upgrade to 300#, due the larger sealing surface.
you should have a means, to remove condensate from your supply air - another topic for somewhere else
you will need a pipe vise in whatever configuration available to you.
you will need a pipe cutter, with a sharp wheel, for a straight cut - a bandsaw or cut off wheel on a grinder wont do. (i have, i have made it work)
you should use a ratcheting handle die for threading.
you could use a non ratcheting one, it will take you longer.
threading oil. also, tilt your work downwards, so, the oil will drip off the threading end, instead of down the pipe.
you do NOT need to double dope a thread with tape and paste.
a quality paste on the threads will suffice.
tape is messy, can easily get cut and pieces get into piping, plus, it looks diy
your not building the space shuttle. piping aint that complicated.
if you lived near, everything needed is here, and, could be lent to you, for the price of a conversation over a beer or three
