I am wanting to use vertical steel siding over 2x6 stick framed walls. The municipality calls for living space insulation codes as the shop will have in-floor heat and plumbing. The back and one sidewall of the shop will be located within 1'-6" of existing 6' fences, allowable zero lot line build. After having hydronic heat before in a mono slab setup, I am really desiring a stem wall foundation to better insulate/isolate the interior slab. It is also important the final 26 x 30 shop blend well with the surrounding wood homes. I find myself stumbling over some details, even after talking with metal building suppliers who really do not seem to be able to offer any input concerning integrating these building methods. My draftsman as well is asking for me to provide him desired details concerning metal siding specifics.
I had planned on stick framing, sheathing, wrapping, strapping, then steel siding. Not wanting to have a large protrusion of the finished wall beyond the foundation stem wall, does one just make the stem wall wider, say the thickness of the 1" strapping? Seems that would allow the use of a typical all metal building protrusion base-molding at the bottom of the steel siding. I really want this detail to be minimalistic and mimic wood T111 or such.
The actual building of two walls in this tight 1'-6" confine is my other dilemma. Not having any steel siding experience, maybe that is sufficient space for a 10' tall siding install though no fun certainly. On a slab I could see the walls being stood up and joined then slid back, but not so much with a stem wall foundation. Any input would much appreciated. I have been watching others on this forum for years and know that others have likely "been there done that!"
TIA
TIA
