Steel storage cart
Bellaireroad
Fort Worth
I'm starting to accumulate a lot of leftovers, and thinking about building a storage cart. If you have one can you show a picture? Not sure if I want to go with horizontal or vertical storage. Thanks
Sent from my iPad using Tapatalk Pro
lis2323
I'm watching this. I KNOW you'll get lots of great ideas. They'll vary depending on one's space available, size and and nature of scraps, and best of all ingenuity and imagination.
danielbuck
I have started sorting metal tubing by length. I found that I kept on having longer tubes in the way of shorter tubes, and what not, so for me this makes sense.
Pieces shorter than 1' go in drawers/bins.
Pieces 1'-3' get placed under my workbench (work bench is just over 3' deep, so the pieces don't stick out).
Pieces longer than 3' I currently just have on the floor or leaning up against the wall, but I will be building a rack of sorts to keep them. I get tubing cut to 10' lengths from the local metal shop, so USUALLY the longest pieces that I have are 10', unless there's a project that needs a piece longer, then I won't have it cut.
lis2323
Not a “cart” but on 4 swivel casters:
My plate shearings (small pieces obviously)
6” crops horizontal. Vertical under 5’
Vertical under 3’
Sheet storage up to 10 gauge with square tube crops on the end. 0e20244e0767b5a4351cf19b5b0c9d74.jpgdc7dafb3a1e0a35ac11d5e91cedc69d1.jpg
sberry
Brethren, Michigan
Engineering division.
bad_idea
Pasquotank, NC
I've got a couple drawers that I store the drop pieces in. The plate is leaned against the wall. The sticks of material are stored on a rack bolted to the studs.
astroracer
Mid_Michigan
Here is one I built a few years ago. Still in use and loaded up.
ry%3D400
Build thread:
https://www.garagejournal.com/forum/showthread.php?t=236804&highlight=roll+round
Mark
