I know the difference in sizing (tubing is measured on the OD, pipe on the ID) and that pipe is typically galvanized but what other differences are there between the two (ignoring DOM and high alloy, like 4130) ?
Pipe is engineered for internal pressure whereas tubing is for structural use.
Beware, the id should never exceed the od with pipe.![]()
Average Joe probably won't be dealing with steel pipe unless he in in the petro chem industry
True, much as a Swanson Speed Square is technically a triangle.bsaint; said:Pipe is a tube. :|
Could they make the pipe sizing any more confusing?
Yep, because if the I.D. is larger than the O.D. you turned your pipe inside out.
J/k![]()
If you use this pipe it will leak very badly and make a mess.
Mike
Move it all to metric?Could they make the pipe sizing any more confusing?
I've never really got a straight answer why it is done this way.
