OK, maybe not the best title, but something I have been pondering and would like some opinions. First a little background. New 34x28 insulated garage with loft space upstairs, currently being built. Exterior is nearly complete with siding being finished, soffit, etc. Inside, getting ready to run electrical. The plan is to insulate with fiberglass batts and install vertical steel panels on the walls in the main floor garage space (mostly due to some grinding and welding work to be done in the space).
I have pre-purchased (because of a deal I couldn't pass up) New Age 12 piece garage cabinets. They cover a span of 13' at a height of 6.5'. This is a considerable section of my back wall. I plan to install them once and leave them in place as they will be lagged to the wall of course.
Here is the question that I am wrestling with: Since the cabinets are essentially permanent fixtures and are best mounted flat against the wall, is it smart to trim out around them (i.e. J-trim as I will use around windows and doors) and not have my steel panels run in behind them? As I am dealing with a new build, I don't have any pre-existing challenges to deal with, it just seems like a cleaner and easier way to install the cabinets.
The major pro that I can think of is a flat surface to mount the cabinets to (no steel ribs to deal with) and less steel to buy and install. Con would be if I want to move the cabinets later, no steel behind, but as I said, I don't plan to do that. Another plus would be electrical is easier to handle without the steel.
Other pros/cons you can think of would be appreciated.
