Wiebster
I’ve searched everywhere on the internet to absolutely no avail. Can someone, anyone please tell me how to install salvaged steel windows into a 2x6 wall with one coat (2 coat) stucco exterior and drywall interior. The window frames are basically 13/16” angle iron flange. I would like to set the windows deep into the framing, flush on the interior. The 1” exterior foam will wrap around the 2x6 and be the return into the framing and stop at the window. I also need room then for the 3/8 - 1/2” thick stucco coat. I would like this final thickness of stucco to just touch or overlap the frame by 1/8”, which I would then caulk. I do understand the attachment points are through the ”jamb” accessible with the window open, not through the face frame like a vinyl window. I thought about screwing a 1x2 perpendicular to the 2x6 flush to the interior and screwing the window into the edge of that. The 1x2 width would accommodate the foam and stucco thickness within the window framing but any twisting of the 2x6 would be amplified where the window attached and affect window sealing and operation. Not sure how to “float” the window within the opening. I’m also creating finishing problems on the interior by having the windows set so deep, not sure how to detail the drywall or trim on the inside either. I realize setting the window in the center of the framing might alleviate some of these issues but it’s not the look I’m going for. Any ideas would be greatly appreciated. Thank you.
