Stem Wall finishing, best/easiest product?
10baggio10
Looking for the easiest product to make the top of this stem wall look nice before I paint it. Thanks20220225_160535.jpg
10baggio10
I thought about that but it won't work for what I want to do. I am looking for a concrete product that is easy to use and will not crack over time if i cover and smooth out the top of the stem wall.
ace10
Rural NoVA
Plenty of premade masonry cap options at big box stores or brick/block suppliers. Attach with adhesive for ease of installation.
GJK1981
They make a sealer that mixes up similar to thin set, but a courser blend. You trowel it on at about 1/8” to 3/16” no more in a coat. It is designed to fully seal concrete or block stem walls or retaining walls, foundations, and finishes smooth and even . Easy to apply and fast.
GJK1981
This is called THOROSEAL. Speak to a masonary retail person and they should be able to help you in picking it out.
FJ4FUN
NorCal
Wolverine Coatings' TrowelEase 1162 epoxy mortar binder. It's like Bondo for concrete, trowel it on, let it cure, grind/sand it to your liking and paint or coat it.
10baggio10
Is there a way to get pricing on this product or actually purchase it?
BombShelter
State of Hockey
There's dozens of products that will work, the biggest issue is the foam will degrade over time and a thin coating of anything will crack. I'd dig out some of the foam, maybe a few inches and fill them in with non-shrink grout or hydraulic concrete before adding a coat on top. Just coating over the foam might be a safety hazard if anyone tries to use a support on the block core.
Inside garages I usually just see a wood board but sometimes they'll have some core-filling, something like Thoroseal (basically a concrete paint) will smooth it out nicely, once it's filled but might be overkill.
