Stem Wall prep before polyurea coat
10baggio10
I would like to coat my stem wall when I do my floors with polyurea but I was wondering if I should fill in the holes on top and if there is anything recommended to use to fill in the holes that is fairly in expensive?
benwah
Lakewood, Colorado
You could use a gypsum cement and trowel it fairly smooth. I like using Schonox, but if you wanted to stay very affordable, Gypcrete. Just be sure to give it a scuff and vacuum after it has setup , before coating.
Deep holes may require a second lift
Armorpoxy
A carefully applied cementious floor patch would work, you may need 2-3 coats due to sinking.
