bad_idea
I have a Quincy 325, powered by a 5HP 3PH motor, run off of a Huanyang 7.5kw VFD. I would like to install two pressure switches to have two speeds for the compressor. For 80% of my uses (home garage), the lowest speed the pump can turn is sufficient.
My thought is to have one switch cut in at 125 PSI and cut out at 175 PSI running the motor at ~30HZ, and the second switch cut in at 100 PSI running the motor at 60HZ.
I am very green to the controls side of a VFD. Anyone have some first hand experience, and can guide me in this? Thanks all.
