due to size restrictions will only be 22' long and 16-17' wide with 8" thick pad for liftso what do you think for strength, durability, etc. will be located in abilene, texas.....thanks for ideas, imputs, recommendations etc.
...guess it depends on location as to whether or not an 'out-building' adds value or not and whether it is metal sided or covered with burlap sacks....
Value is a perceived condition and only has an affect if you are building for immediate re-sale of the property.
And, 'tin-shop' is a red herring since it does not say anything about the actual construction. I put steel siding on an ICF structure and I doubt that it would chase away potential buyers.
As to the OP, you will always be better served, IF you are in a subdivision, to have the shop look like the main house. If you are on acreage and cannot see your neighbor then let your checkbook, and local codes, decide.
If you worry about the occasional tornado then consider ICF.
It doesn't depend where you live.
Facts are
Appraisals, the thing others use to get money from the bank say
No added value. Almost always, almost without exception.
You have a skewed view because of your investment.
Pool owners also share this skewed view.
