stick built or pole barn in NJ
mikhett
jackson nj
I havea attached one car garage on the home I built in 1997 on 1 acre.Im too old (64) to build a garage myself ,so I was wondering what would be cheaper to build .I have a 62 ford galaxie I did a frame up on and completed in 2007.Now im in the process of doing a F.O. on a 1956 ford Victoria.I need MORE ROOM!
jrsulo
New Jersey
Was in Jackson today,,,,see a lot of pole barns there so thats what I would do,,,,,and they are cheaper and fast !!!!
morrillm06
Moultonborough NH
Im in the same boat, pole barn vs. stick What did you decide?? I like the thought of a pole barn but im also concerned about post rotting down the road, im only 27 and I plan on living where I am for life.(just finished building the house 1.5 years ago). also this will be heated and I don't know if one is easier than the other to insulate.
deepsky62
I live in rural Ohio, if you know about Ohio the saying here is "Wait a minute, and the weather will change". That said I know many, many pole barn owners, and have had work done, hay stored, cattle butchered, and equipment stored in them.
Two things to keep in mind, temperature, and moisture. To achieve temperature control you need insulation. and heat. Pest control is mandatory with a pole barn not sealed up. With moisture there has to be vapor barrier in walls, and floor, so no gravel, must be concrete. With these factors, you may need a sealed up garage, but if you need room, pole barn is the answer.
Lastly, I have barns that are nearly 100 yrs old in my area, on pole construction, the walls rotted before the poles were affected. You will never live to see the end of your barn. I have seen houses that did not last as long as some pole barns.
