Comparing stick built vs Pole is a back and forth debate per application. If you live in a rural area, doing a pole building is often cheaper since you can go much larger (most codes dictate 850sqft being the largerst you can go without footings) so anything over 850sqft it becomes a bit cheaper since your not pouring trench footings which, here in IA, the going rate is $55-60/foot for a 12" wide x 42" deep footing, so that amount adds up quickly. if you live in a residential neighborhood often so you dont look like a kick you want the exterior finished off so you can side/roof it to blend in with the nieghborhood...doing that dwith a pole building requires a bunch of extra lumber so then it becomes a wash. If you plan on insulating by using batt insulation, then it'll add up even more since if doing a pole building you'll have to build bookshelves so you can lay the insulation in horizontally to get a decent r value, then furring stuff out so you can get a nice flush wall, or furring out so interior wall sheathing has a place to screw/nail too.
if it's just cold storage-pre steel prices going through the roof, often the pole barn always came out ahead in saving money, if it does'nt ahve to blend in with the neighborhood, but we build garages/additions and remodel and i bought ahouse with no garage so have a blank canvas. I drag race and my company trucks need a 10' tall door so i need a taller structure, but i want it to blend in with the nieghborhood. I prices out going ICF's, stick built, pole building finished to look like a stick built on the exterior and in doing so the pole building ended up running about $8K more than stick building it initally with all the added furring strips and such for insulation, or if i end up having spray on insulation.
It's late and i could go on and give alot more examples, but i need to hit the sack. if you could post some other more specific questions i'd be happy to help you with pro's con's unless your just posting this as a something to think about thread?
josh
