Pipe Wrench
- Joined
- Feb 11, 2017
- Messages
- 66
This is for covering up a ratty looking kitchen floor that is covered in square 12" vinyl tiles.
I know that those cheap sticky vinyl tiles I see at THD are not very good. If there is a better and not much more costly alternative, I will consider it. Please advise, if you have suggestions.
If I end up using the sticky tiles, I wonder if I should use additional adhesive. And if I use additional adhesive, will those tiles and the adhesive be removable without destroying the underlying original vinyl floor.
How about the procedure?
Clean original floor as good as possible (scrub, degreaser etc)
Make sure surface is absolutely free of cleaner residue/grease/etc
Use vinyl primer
Attach self-adhesive tiles with additional adhesive
Use a heavy roller
Use vinyl primer
Use a heavy roller
