Hope this is OK here...
Have a 8-9 year old MS 290 I bought new. Low hours overall. Put about 3 hours on it two weeks ago where it worked fine, went to start it the other day and...nothing. I thought I had no spark (because I was trying to ground out the plug on the carb instead of the cylinder), so I replaced the ignition module and spark plug. Needless to say, spark is now fine. New air filter, new 2-cyc mix. What is weird is after sitting for a few days, it will usually start the first time ONLY. For example, after bolting it back together after replacing the ignition module, it fired on the first pull. Ran it for 10-15 seconds, then noticed the chain was loose so shut it down. Tightened the chain, went to restart, and ...nothing again. It's never been straight gassed. Cleaned the carb thoroughly while I had it apart for the ignition module. Any thoughts?
