Stinky Hands from MIG welding
PKAero
Southern by the grace of God!
Hi Guys
I know this is a weird subject, but when I MIG weld without gloves my hands have a strange odor. Does anybody know what causes this? Its been about ten hours since I welded some rebar and I can smell them as I am typing this.
P
PKAero
I normally wear gloves, but this was a small job with only a few seconds at low amperage. No evidence of burned skin or singed hair. I read somewhere that ozone is produced during welding. Could this be ozone odor?
cide1
When I cut metal with a chop saw, the fumes make my stomach upset. Doing it outside seems to resolve the issue.
I've never migged without at least a pair of mechanix gloves.
1967marti
It's from the melting of the metal during welding... It will happen every time you weld without covering-up. Now imagine all that **** that is making your skin stink is getting in your lungs unless you wear a mask!!
P
PKAero
What is it about melting metal that makes you stink? I dont have the smell when I torch cut. Do workers in steel mills smell this way?
koditten
Midland, Michigan
It's super fun when spatter sticks to the wedding ring. Gold is such a good conductor of heat.
Holy ****, did I make that mistake! Slag stuck to the ring, attempted to rip the ring off to stop the pain, took 1/2 " square of hide with it. Boy did that take forever to heal.
KO
bad_idea
Pasquotank, NC
Damn koditten! I was lucky, it was a couple small bb's that stuck to my ring. Just enough to irritate me into sending it into the jeweler to be fixed.
AZ_Catskinner
Morenci, AZ
Off gas!! Great stuff. Steel stinks, moly turns your skin gray, copper gives you a nice greenish tinge, arsenic makes your smokes taste like menthols mixed with sugar........
Working in the smelter taught me all sorts about molten metal!!
cide1
The plasma cutter has a distinctive smell, but I don't think it stinks. My wife doesn't like it, but it doesn't bother me.
jdcompman
South Dakota
I always just thought it was burnt skin smell from the UV exposure. Very similar to when women go tanning in a tanning bed.
trbomax
starvation lake,mi.
In regard to all the "ring" posts,you shouldnt be wearing any kind of jewelry when you are fabricateing.A lot of fingers get snatched off that way.I saw a guy loose a finger because of a ring when I was around 18 yrs old.Ever since there have been no watches,rings or anything else on my hands,and after 55 yrs of doing it, I still have all my fingers.They do stink after mig welding though.After a day of welding,cutting, grinding,everything stinks like burned metal. I love it!
Test Tech
Automation Alley
I've noticed the chop saw upset stomach thing too. Vaguely like heartburn.
bad_idea
Pasquotank, NC
I would think it is better to weld bare handed than with mechanic's gloves on. All of the mechanic's gloves I have used have nylon on them or plastic or whatever the hell that is. That stuff melts and sticks to you!
jsaw
Geneva, N.Y.
I notice a bad smell after TIG welding. I figured that it had something to do with the shielding gas combined with the arc. It doesn't smell good to me at all.
P
PKAero
I found this article about ozone and its reaction on skin:
http://www.rsc.org/chemistryworld/News/2009/August/18080901.asp
The newly identified compounds are likely to be produced when the ozone reacts with squalene, an organic compound, and unsaturated fatty acids, both of which are found on the human skin. The study suggested that a single human can remove up to a quarter of all ozone in a similar-sized office via this reaction.
However, the study may also have implications for methods of outdoor air-pollution analysis. Squalene and fatty acids are also found on various outdoor surfaces, including plants, buildings and the sea surface, and so have the potential to react with ozone here too. 'To a large extent, the resultant products are likely to have been overlooked in surveys of outdoor pollutants for the same reasons that they have been overlooked in indoor pollutants - analytical methods have been used that were not suited to the detection of easily oxidised or highly functionalised compounds,' the researchers note.
P
PKAero
Collectively these studies benefited from earlier work by Fruekilde et al. (12), which demonstrated that ozone reacted with human skin lipids to produce acetone, 6-methyl-5-hepten-2-one (6-MHO), geranyl acetone and 4-oxo-pentanal (4-OPA) and that squalene was the major precursor for these oxidation products
Sounds stinky to me.
tomshep
+1.
You guys are crazy for working with ANY jewelry, watch, etc. on.
Tom
