Hi,
I am considering using Epoxy-Coat for my garage floor. The garage floor is, I believe, currently coated with garage paint and some flakes. The paint has come up in several rough spots, but is adhering fine where the concrete is more or less smooth. The rough spots are spots where the original pour seems to have been poorly done, and there are many small stones at the surface of the concrete. I don't believe it would be possible to grind this smooth, as you would simply chip out all the stones leaving an even rougher floor (which is otherwise known as my driveway). There are no cracks in the floor, save the two expansion joints dividing the floor into four sections. The floor is 30 years old. The floor is clean, with no obvious evidence of oil or other spill spots.
While I would love to have a perfectly smooth floor, I don't know that this is possible. How well will the 100 percent epoxy adhere to the stony surface? Will it smooth it somewhat?
I have three images here, as pictures are always better than words:
I believe I am comfortable with putting on the epoxy. I will be doing this alone and I do wonder if grinding is above what I can afford and do. Epoxy-Coat seems to state that sandpaper on existing coats is good enough. I don't believe the floor has been sealed... just painted. The paint is not actively peeling anywhere. It simply has come up on the rough spots in the past. I've had the house two years, and with active use and a car in and out, there has been no real change.
Suggestions/advice for a man with only himself to work with and not too much money to spend?
