Storage bed for my daughter
Dataguy
Northern MI
So, my daughter off at college has run short of room in her apartment. (Shocking, I know). Anyway, she had been looking at storage beds with drawers underneath the mattress and asked me if I could make one because she thought the ones from Ikea and such looked cheap and likely to fall apart.
After completing the project, I think it might have been cheaper to hire some downstate Amish to buggy on up here and build it by hand. :lol_hitti
Despite that, it came out pretty well. Here's a few pictures. Forgive the messy basement in the background. I was doing this in the garage, but it's too cold out this time of year to do the staining/finishing so I brought the carcasses into the basement for the finish work.
Here's a carcass without the top cover, showing the drawers:
Here's a drawer extended out:
And here's a carcass with the top on:
This one shows the 3 carcasses put together on the floor. Each one is 60" x 20", so the total area is 60" x 80", which fits a queen-sized mattress. On the inside is a 2x4 mounted to each carcass with oak risers. The ladder structure both supports the middle of the mattress and serves to tie all 3 units together.
This shows the ladder structure in place:
And here it is with the plywood cover in place. The pressure from the mattress holds it all in place:
And this is the overall view (no drawers in place):
It took a while, but a very satisfying project overall. It's mostly made of 3/4" cabinet-grade birch plywood, but the drawer fronts and trim were made of 1" solid birch board planed down to 3/4" and glued together using biscuits.
She's been using it for a couple of weeks and it hasn't collapsed yet, so I'm declaring success. :beer:
D
Dataguy
Northern MI
Thanks for the kind words. It was pretty easy to move into her place, although each unit weighs around 100 lbs with the drawers in place. I used self-retracting slides so they don't slide out when you're jockeying things around through doorways and such.
I have to say I learned a lot during the project. I couldn't find any plans that I really liked, so I started with a sorta-kinda set of plans I found here:
http://www.ana-white.com/2009/11/queen-sized-storage-bed
and went from there.
I thought the 60" span was a long unsupported span for a bed, so I added a support in the middle beneath the divider for the drawers. Note: it's hard to find a 4x4 these days that's untreated. I didn't want treated lumber for furniture (that stuff can be nasty), and finally found a cedar 4x4 at a local lumber/hardware store.
I also routed out a slot for the drawer base, 1/4" deep and 3/4" wide (true 3/4" because the birch plywood is 3/4", not 23/32").
For the sides of the carcasses, I drilled into the vertical edge of the back piece and inserted 3/8" dowels, then cut them off flush. That gave me some nice hardwood to drill and screw into. The birch plywood has good screw holding capabilities in general, but for those pieces I wanted a little more oomph.
The drawers are made of 1/2" birch plywood with both screws and biscuits. The drawer bottoms rest on 3/4" x 3/4" fir strips glued to the drawer sides/front/back. The bottoms are glued in place and nailed with a brad gun.
Most pieces were drilled with a countersink drill bit and attached with #8 x 1-1/2" wood screws. The tops of the units were the only pieces I didn't glue in place, as the drawers are hard to work on with the tops in place. I wanted to make it possible to open them up if needed. (Not that I don't have perfect faith in my design or construction...:lol:)
The finish was a pecan stain she picked out, then 3 coats of Minwax Polycrylic, a light sanding with 220 grit, and a final coat of Polycrylic.
This was the first thing I've ever done with a biscuit joiner. Why did I not buy one of these sooner? It's an amazing tool for wood joinery.
Now to fix the ramps on my trailer...:lol_hitti
4EyedTurd
Texas
Beautiful job, and even better your daughter asked you to make her something that was flimsy.
