I am afraid you might be right, but I am hoping someone has some genius idea. They had three of these cabinets at the 2nd hand store and they are awesome, so I bought all three. I don't have enough small parts/tools to fill them and I am hoping to find a way to expand my options for using them.Wow, I would love to have a cabinet like thatI think those dividers are going to be almost impossible to remove without doing some damage
They possibly are spot welded in place. Might be possible to drill them out (or use a spot weld cutter).
Use a spot weld cutter. It is an annular cutter with a spring loaded pilot. Used carefully, it won't cut through the drawer bottom.
That is my understanding as well. I live in Utah and a huge effort was made (and continues to be made) by The Church of Jesus Christ of Latter Day Saints to research genealogy, much of which was done with microfilm.I think those cabinets stored microfilm rolls.
In the old days newspapers and other documents were microfilmed. The films were on spools/reels and were fed into a projector/reader and the microfilm was projected onto a screen on the bottom of the reader.
Thanks Chris, great feedback. I guess I just need to grow my small hardware collection.I use those exact Russ Basset cabinets for hardware storage, with Akro Mils bins and bin cups. Fit perfectly between the dividers. Those dividers provide a lot of the rigidity that allowed these things to be filled with massive weights of microfilm. With them removed, I think the drawer load capacity goes way way down. I've found that between things like hardware, motorcycle carbs, bulbs, fuses, wiper blades, batteries, USB cables, household smalls, etc. I was able to organize a lot of my life into those.
These things are super well designed (drawer interlocks, massive weight capacity, leveling feet, etc.) but as you remove rigidity you may find the drawer bottom interfering with the drawer face below, increased tendencies to introduce racking, etc.
I've never had problems selling my extras for about $300 each, so you might consider moving them on whole, while they still have value, if they won't work for you.
Could still use the space for storage of seldom used items or things related to whatever is on top. For example put 1/4" impact driver on the top and spare bits underneath.lay masonite on top of the ones you want gone. You lose depth but get your flat surface. You can even just use the masonite on the part of the drawer you need flat.
Thanks Itinerant, glad to know it works without a few dividers. How did you remove them?
I'll give that a try.The dividers are not attached to the front or back of the drawer and so add little or no rigidity to the drawer itself. To remove the dividers, I simply bent them back and forth gently until the welds popped and then used a hammer and dolly to peen down the edges where the welds had been.
