Storing flashlight batteries
Brad54
I've become my dad... I have flashlights stashed in drawers and cabinets all over the damn house.
Batteries, when plugged into whatever machine they're in, end up dying and corroding. They don't in the package, so...
How should I store batteries in the flashlight so they last? I don't care if I have to take the flashlight apart, swap the batteries around, remove a piece of tape from the contacts, or whatever, when I grab it.
-Brad
AZ Pete
Central Arizona
I use to keep a piece of card board between the battery and contact in my emergency head lamp. Works.
CJM8515
Cardboard I hear works. I like to store batteries next to the light if possible. The lithium ones dont corrode as bad as the alkaline. Also duracells IDK always blow as do rayovac, but I never had an issue with energizer. Also rayovac dont last as long.
PassnThru
Bowling Green KY
Several years ago I invested in the Craftsman Nextec series of 12V cordless tools with Lithium Ion batteries. Nice part about the batteries is they don't have issues being stored in the tool and they hold their charge for a very long time. Since I have tools that use the same batteries then I usually have more than one on charge or fully charged at any given time. The set includes a LED flashlight - the flashlight without a battery I believe was under $10. I now have three of them - one of which stays in the house. The other two are in the attached and detached garage with about 5 additional batteries.
My belabored point is - look at flashlights for your cordless tools - they make great in house flashlights. Take the batteries out of your backup flashlights and reload them when needed.
honcho
Near Sodom & Gommorah (aka Wash. DC)
Alkaline batteries are sometimes referred to as "alkaleaks" due to their nature of leakage and corrosion. There are several ways to combat the problem
1. Don't use alkaline or zinc carbon batteries. My preferred battery is the AA and AAA Energizer Ultimate Lithiums. These are disposable, not rechargeable, batteries. They are expensive at retail, approximately $10 for 4 batteries. Energizer claims 8-9 times the capacity of alkaline batteries and, in some applications, they definitely live up to that claim. They have a very long shelf life and so are good for standby emergency use. Other benefits are that the lithium batteries are lighter than other types of AA cells and have much better cold temperature performance. Alternately, you can use the Panasonic (formerly Sanyo) made in Japan Eneloop NiMh rechargeable batteries. Unlike ordinary NiMh batteries, these have a low self-discharge so you can leave them in equipment for extended periods of time with some assurance that they will have juice when you need it.
If you have equipment that uses C or D size batteries, you can use AA batteries with adapters. You will lose some capacity but it's nice being able to power a bunch of different things with a single size of battery cell.
2. Next best thing is to never store your equipment with batteries installed. I've seen more than a few Maglites with stuck corroded batteries that have rendered the flashlights unusable.
3. If you're sufficiently organized, routinely replace batteries before they have a chance to go dead. They don't leak unless they're dead
4. Last, use cheap equipment and throw it away when damaged. I'm not fond of throw-away culture but for some things, the economics can make sense.
nes999
IL
I haven't had a leaky battery since I put dielectric grease on the terminals. I don't know why it works, but it does.
Sent from my VS985 4G using Tapatalk
R. Johnson
CT
Dielectric grease on the terminals will solve a lot of problems. It coats the terminal so the chemical reaction between the leaking battery acid and oxygen can't happen leading to less or no corrosion. You'll still have a leaky dead battery but atleast you can just replace it without having to clean the terminals.
johninct
-Brad
If you have ever lost power for a week, keeping flashlights all over will be a very good thing to have done.
Infinia
SoCal
get rid of those Alkaleaks
If you have flashlights / gear you'd rather not replace, time to investigate the new world of NiMh rechargeable low self discharge cells (LSD). see honchos post #6
Fry's usually has sales on 'Tenergy Centera' LSD about a buck a piece.
Infinia
SoCal
a week? yikes
forgot to pay your power bill:lol_hitti
I have a AA/ AAA recharger with 12V or 120V inputs so I can run it from any car /truck. I'm invested totally in LSD AA's also have C/D adapters to fit old oddball maglites.
gdocktor3
Connecticut
My grandparents always kept their batteries in the fridge. What if you just stuck the entire flashlight in the fridge...
Infinia
SoCal
Don't think there is much to gain lowering the temp, besides batteries are cheap, really cheap in bulk (if you go for consumables err landfill ). In a power outage we don't allow the fridge to opened unless 8-10 hours or things have started defrosting. so no...
