Stove top burner
Reg1952
Ontario Canada
What is the resistance value for the large and the small electric stove elements? Got some getting slow to heat up.
zmaxmotorsports
South of omaha
Check the connections for grease/crud.
I've never ohm'ed one out before.
If in doubt swap it with a good burner from other side and see what it does.
Milton Shaw
Elements run in the range of 14 -20 ohms. Most stoves use a switch that turns on and off different amounts from 100% at high to 10% on low. If the element heats at all is probably good.. On real old stoves that had push button controls the element had three different sections, all got 240 on high, one section 240 on 2, 240 with elements in series on 3, 120 on all on 4 and 120 on one on low. Those went away about 30 years ago. If it is slow to heat, check the connections at the element and replace the switch if nothing is wrong with the connections.
R
Reg1952
Ontario Canada
Thanks guys. checked all 4 with my meter and all are good. Tightened up the terminals on the connector block and now it get hot at same rate as the other one.
