Straighten Twisted Aluminum Window Channel
itstippy
Madison, WI
I backed up my pickup with the cap door open and mashed it into a tree. The plexiglass shattered and the aluminum window frame bent in a lower corner, quite impressively. I want to straighten the bent frame so the window repair folks can put in a replacement piece of plexiglass. They did this for me once before when someone threw a rock through the original tinted safety glass; that time the window channel wasn't bent all out of shape, though. What's my best bet on straightening this twisted channel? Heat with a torch? Bend slowly? Hammer into place with sharp raps? It doesn't have to be pristine; it's a working/camping truck. Attached are pics of the unbent corner and the twisted corner. Ignore the date, my camera is whack, I destroyed the window just yesterday.
matt_i
I think I'd try to put some shims or flat stock in the bend. Try to get the gross bend back with a vise. Then get the correct size spacer inside the channel and you can try to hammer form it -- gently. Being aluminum and lacking ductility it could crack. Not a real easy to anneal it.
In worst case you could cut out the bent part and go back with steel which would be a lot easier to tig weld into a channel, then pop-rivet or screw to the other part of the window.
joe49
Tonica, Il
What you have in the way of tools? Vice, torch, vice grips, seamers, soft hammers, the tools available will give a better direction to follow. Your experience is still the hurdle.
I
itstippy
Madison, WI
Thanks guys, I got 'er done. At one point I had that thing clamped six ways to Sunday. I used wood blocks and metal shims (the bar from a bar clamp and the bolt from an antique lockset). It looked like garage art. Lessons learned:
* Aluminum window channel can be clamped tightly and coaxed back into place without cracking. No heat, no pounding.
* Do not back your truck into a tree with the cap door open.
