AndrewDouglasBird
Some of you may have seen in my other thread about my garage door gap, the walls of my garage were bowing out several inches and the boards running across to each wall were tearing out of the studs they were mounted to.
Temp fix
Pulled WAY away.
Temp fix
This one split the stud in half.
Temp fix
So all of that got torn down and 3 new 2x6s were put up in their place. A come a long was used to pull the walls back together. Screwed a d-ring mount in the top plate on each side with 2-1/5" long 3/8" diameter lag bolts. Worked great.
Next came cross bracing and re-hanging the garage door opener.
Also re-structured the door track hangers. They were mounted poorly before. Now they are rock solid. You can also see the d-ring used to pull the walls together.
Then, finally, supports up to the rafters were added. These added a TON of rigidity. Even with all the previous bracing, the 2x6s would flex down a lot with little weight. Now bouncing on them barely moves them.
Still need to run power to the garage door opener, plus add a few lights back in that were taken down. All in all, THAT WAS A LOT OF WORK!
Did I mention this is a rental? lol
Temp fix
Pulled WAY away.
Temp fix
Temp fix
