Innovate1
Looking at using a Leviton 3033 switch with #10 wire. One of the wires will be stranded cord (SJOOW). I didn't see any notes on the data sheets about type of wire so thinking stranded is ok. This has clamps not back stabs. Looks like I need a box about 27 cu. in. so may need to go to a dual gang box to have enough room. Three cables - each 2 conductor plus ground - 2 cables are NM-b and one SJOOW. Planning to use an old work plastic box. It's in an RV so no studs to fasten to. Think I will glue a ring of 1/4" plywood behind the thin paneling to give it a bit more support.
