Stranded wire vs. Solid wire
d.reinhart
Bloomville
My walls have purlins on them which I was thinking of running conduit underneath the Pearl on to my Outlets boxes before I drywall I was wondering what your guys's opinion is versus running the solid wire and not conduit or running kind of stranded wire inside the wall
pizza
Midwest, USA
i associate conduit with quality, but it's honestly a waste of time and money if used where not required.
i always try to do conduit, though. romex is only for hidden retrofit pulls where conduit doesn't already exist ;p
sparky 1971
Central Iowa
I use stranded almost exclusively because it's easier to pull by myself. It can also create a helluva tangled up mess in a hurry. If you have help pulling, use solid.
haveissues
Hudson Valley NY
But harder to terminate
If you use the better devices they have built in clamps that make terminating stranded super fast. I just did my whole shop in emt and stranded since I had a bunch of rolls left over and romex is so stupidly expensive right now and rather enjoyed working with it.
Terry D
St. Louis, MO.
If this was exposed work, I defiantly would use conduit. But since it is inside the wall, I would use NM-b or MC. I guess the practices are different across the country, stranded is all that gets put in pipe here these days. I honestly don't think I have ever bought a roll of solid THWN. It is slightly cheaper than stranded though. If you do go with the EMT and stranded wire route, use back wired devices. Those are the correct devices to use for terminating stranded wire.
finn
The UP, God's country
For a shop, exposed conduit and solid for 10, 12, or 14, but stranded for 8 or heavier.
I hate hidden circuits in shops, and stranded is definitely harder to terminate unless you’re a skilled electrician.
sparky 1971
Central Iowa
Anyone that uses #10 solid in conduit is a much tougher s.o.b. than me. Terminating stranded is actually easier than solid when using the proper devices.
Terry D
St. Louis, MO.
Use back wired devices with pressure plates. I am not a big fan of striping stranded wire and leaving the insulation on the end and twisting it before wrapping it around a screw.
Bert_
NW Iowa
Pipe in the wall does take a little skill. I actually really like doing it. Often I'll do a hybrid, Smurf tube where it runs through studs and EMT from the rest. I've done a couple buildings with 100% EMT but it does add some labor
engineer2
Chicago burbs
Conduit makes future modifications or upgrades much easier.
If I were building a shop, I would use 3/4 EMT for home runs where it makes sense.
If I were building a house, I would use 3/4 EMT for home runs that pass between floors.
We use solid wire in conduit with no problems as long as you follow established conduit fill rules. Solid is a little cheaper than stranded.
engineer2
Chicago burbs
9 - #12's will fit in 1/2"EMT. It's almost impossible to do with stranded, let alone solid
Yea, that's going to be torture to pull over a distance with bends. I can't think of a situation where you would do that except maybe a residential kitchen if local code requires it, but two home runs would be smarter or Edison circuits to the rescue! Industrial you would run 3/4.
dscheidt
It's pretty common in retrofit situations. The conduit is in a finished wall, so you have to use what you have. My house (built 1920, rewired 2016) has two or three 1/2 conduits like that. They split up at the first box, so it's not very far, but it does lead to some strange circuit sharing.
finn
Now that I think about it, the 10 is probably either stranded or Romex. There’s only about five feet of it for a compressor, and it’s been there behind the wall for years.
I do have #8 stranded in a conduit, and that wasn’t much fun.
engineer2
Chicago burbs
I pulled three #6 stranded a total of 60 feet in 3/4 EMT. Had a J-box every 20 ft. It wasn't bad and I used plenty of lube.
engineer2
Chicago burbs
Why the boxes? 60' isn't very far.
One was for future use near the garage wall (probably will never use it), the other was the LB where it came to the outside. It was a pretty easy pull, only four 90°s not including the LB. The underground was 1" RMC. I didn't even need to get my wife to feed wire like she usually does.
