marrt
I have a house with a detached garage. When starting to add some insulation to the garage I removed a switch in the garage that controls an outside light above the garage door. Power for this switch is coming from the house. I was in a hurry and didn't notice this is a three way switch. That's normally not problem...however, the original electrician ran two standard 14-2 UF wires from the house to this switch and didn't mark anything. So, I have two black, two white and two ground wires coming from the house.
So far, I've identified the common and traveler wires and rewired the switch in the garage. It works fine from the garage and inside the house. With one problem...I have a wire left over. Since the electrician used two 14-2 UF wires instead of one 14-3, I have a wire in the garage (black in this case) that isn't connected to anything. Worse, when the house switch is in a certain position, this wire is hot (the switch in the garage doesn't affect this wire, as currently wired).
What do I do with this wire? Put a wire nut on it and push it back in the box?
