Strange Motor Problem Instantly Trips Breaker When Plugged In
willf650
There may be something wrong with your unit. But with what you described you have the hot and neutral crossed in your cord setup would be my guess as a starting point.
There should be no path for the current and gfi to trip if the switch is off unless you have wires crossed.
Cruzan80
Denver, CO
Can someone explain how, with his switch OFF, it's still tripping the GFCI?
If the switch is single-pole, and switching the neutral, not the hot, then he could be losing current to ground past the switch (either broken wires inside the yellow cord, or in the motor itself). That would trip the GFCI, even with it "off". It could easily be low enough that his meter didn't catch it, depending on what mode he was in (no load=phantom readings)
Maui
Upstate NY
Given the second unit has a black wire coming out of the motor, it means that all you have identified is that from the white round plug onwards is good. Anything from the yellow prongs back on the first is suspect.
It could be the yellow cord is miswired, broken inside, or a bad connection inside the motor, or grinding dust, or... You need to take the meter out of continuity mode and start checking for resistance, etc, just like you would on any other given suspect motor.
There were several questions about the GFCI being faulty as well as the switched power cord that I wired up being incorrectly wired. This one test should demonstrate that this is not the case. The yellow cord is brand new, and has not been miswired.
I will be happy to provide photos of the opened plug as Frank Lee requested.
Cruzan80
Denver, CO
No, actually it just showed the GFCI outlet and switch/plug can work with a known good motor. If the switch is wired to break the neutral and not the hot, it would still have the issues described.
I wasn't saying the yellow portion was definitely miswired, but anything from a "known good point" back is suspect. There still could be an internal break in the yellow wires insulation, or theconnections at the motor, or the windings, or dust, or... That was my only point.
signcrafter
As it turns out I have another Hook-eye unit that I purchased several years ago. I just dug it out and even though it wasn't required, I used the same switched extension cord that I used previously with the other Hook-eye unit to plug in into the outlet. When I flipped the switch on the machine it sprang to life immediately with no issues. I turned it off and then turned it back on again. It ran again without any issues whatsoever. It is obvious that the motor on the other Hook-eye unit has some sort of electrical problem that has yet to be conclusively diagnosed.
But the 1st unit trips the gfi even with the switch off? I'm not an expert but the gfi works by monitoring the current of the hot and neutral so if the switch is off there shouldn't be current to monitor right?
paulsomlo
Northern Colorado
How are you "checking continuity"? If you just have a meter that beeps when there's a short, you aren't going to see a high impedance somewhere. It'll just not be a dead short.
Agreed - instead of checking for continuity, go back and do all the same checks with an ohm meter. Your readings should be in the megohm range. If that checks out, the only thing left is a large capacitance between hot and neutral.
PCustoms
VT
Ok, this is exactly what I've been thinking.
To start, he's got something wired wrong. With the switch OFF, whatever issue he has should not trip the GFCI
Maui
Upstate NY
The switch is wired to break the hot connection, not the neutral.
Maui
Upstate NY
If the switch is turned off then there shouldn't be any current flow, correct. It appears that there is some current bleeding from neutral to ground inside the motor with the switch in the off position that is causing the GFCI to trip.
signcrafter
That is my thinking. And the gfi monitors the difference between the hot and neutral so if the switch is off there shouldn't be any current flowing so there shouldn't be any difference in between the hot and neutral. Even if the neutral and ground are touching. That shouldn't matter until you turn the switch on and the current flows.
Not sure if it's been said but your switch is switching the black hot wire right?
signcrafter
There has to be something going on with the wiring and not just an issue with the motor. My guess is that there is an issue with the motor, maybe dust or something allowing the neutral and ground to make contact. This would create an imbalance between the hot and neutral. But that shouldn't matter until the switch is flipped. Not sure what the issue is but in my head the gfi should not trip until you turn the switch on, even if there is an issue with the motor. Like mentioned it sounds like the hot and neutral are reversed somewhere. If that is the case then you have hot going to motor even with switch off and guessing flowing back on the ground since the neutral would be broke with switch off, thus creating your imbalance between the hot and neutral. Not sure why the other motor works fine with the same switch. Are the hots hooked to the same spot on both motors?
PCustoms
VT
The other motor works fine because it doesn't have a leakage to ground.
OP needs to probe the receptacle on his switch cord to see if he has voltage with the switch OFF
Cruzan80
Denver, CO
So something is incorrect. You could put a jumper tying neutral and ground together and it wouldnt trip a GFCI if the hot line is off/not connected to anything.
Something is letting hot current pass to another wire. Either the switch is faulty, mis-wired, there is a intermittent break in one of the lines, the incoming wire to the outlet is mixed up, or something. But as it sits, something is incorrect leading hot to be live when you think it isn't (switch off). So you need to figure that out first, then diagnose the motor afterwards. The motor has issues that are revealing the problem with the switch, not that the motor is the only issue.
The easiest way is the outlet tester @PCustoms mentioned above (they are under $20). You could also probe with a meter carefully if you need to to diagnose. But either way, you should fix the wiring first.
Maui
Upstate NY
The hots are connected to the same spots on both motors, yes.
Maui
Upstate NY
I removed the extension cord shown in the photos I already posted that has the switch wired into it and just plugged the yellow wire directly into the outlet (so there was no switch in the circuit at all). What happened was interesting. The GFCI tripped almost immediately yet again, but not before the motor was able to rotate for maybe a revolution or two. I could hear it move.
For the record, the yellow wire was taken from a large coil of brand new wire that I have been using for over a year to repair other motors over that time period. It has worked flawlessly. I checked each wire in that power cord I just made from it this morning several times from the plug to the connectors that attach to the motor. They all show continuity like they should. And in the photos you can see which wires are connected to what prongs on the connector, and how those same wires are connected to the motor.
The problem must be inside the motor.
PCustoms
VT
@Maui
STOP
You have 2 issue:
1) your motor is leaking current to ground
2) something (your switch or outlet) is wired wrong.
You should diagnose #2 first. You cannot rely on the wire color, you will have to do some testing. With the switch plugged in and OFF, set your meter to check voltage and probe the outlet coming out of the switch:
Hot to ground
Neutral to ground
Hot to neutral
Now turn the switch ON and repeat. Report values back
Cruzan80
Denver, CO
Yes, the motor has something that is leaking current.
The bigger and scarier issue is the the switch box or GFCI itself must have something wrong with it as well, which you only noticed because of the bad motor. Otherwise, the switch (when OFF), would not trip the GFCI, regardless of good or bad motor.
But at this point, you have multiple people telling you the same thing. I am out.
Edit: cross-posted with @PCustoms .
Maui
Upstate NY
@Maui
STOP
You have 2 issue:
Hot to ground
Neutral to ground
Hot to neutral
When I had the inspection done on this house before buying it it was discovered that the Jacuzzi tub had been wired improperly and represented a serious potential safety hazard. I had them bring in a pro to wire it correctly before purchase. As it turns out, the previous owner had done the wiring job himself and got it wrong. It would not shock me if he wired this outlet up himself, and got that wrong too. Best to check. I'll let you know what I find.
The outlet thingie posted above is a quick and relatively cheap test $20ish I imagine, vs bringing in an electrician. When my last two houses were inspected, the guy poked one into every outlet.
Maui
Upstate NY
I just found the very outlet tester PCustoms included in his post on Amazon for about $10. It should arrive some time next week.
Higgins
Shepheardsville, KY
I have a vintage 1/4 horsepower single phase motor that is used to power a Hook-Eye knife sharpener. The guy I bought it from told me that it doesn't work, but everything is there. It doesn't appear to be missing any parts, and the motor shaft turns freely. You can spin it with your fingers easily. When I plugged it in it with the switch in the "OFF" position it immediately tripped the in-line breaker on the outlet. I checked the connections between the power cord and switch, found a few loose connections, squared everything up, and the same thing still happened. I removed the power cord and switch that came with it and put them aside, and wired up a brand new power cord, plug and switch that I know is wired correctly and works properly - and I verified this with my ohm meter. Again, I plugged it in with the switch in the "OFF" position so there should not be a completed circuit, and it immediately tripped the breaker again. To make sure the outlet wasn't the problem I plugged my bench top drill press into the same outlet and when I turned it on it fired right up like normal. I checked for connections to ground from the common lead and the hot lead and found none.
I am truly puzzled. How can a motor trip the breaker with the properly wired switch turned OFF??
Brushed are probably gone! See if placements are available!
OccupantRJ
Eastern North Carolina
They are well worth having for diagnostics. I was at the beach last week and made $100 tip with one checking outlets in a nearby beach house during the time I was there doing a repair for a relative. One receptacle had a bad connection and was intermittently working.
Hannahranga
Are you plugging it directly into the GFCI that's tripping? If there's other loads also on that GFCI they'll provide the current flowing back through the ground to trip when someone plugs in a faulty item with a neutral to ground short.
john.k
Brisbane Qld Australia
I had an issue at work with 300 amp fuses blowing ocassionally. on a compressor......I thought maybe undersized, so I tried some 600 amp I had ........the explosion blew the door off the starter box ,and vaporized the switch gear...........I quickly removed the evidence ,and reported the incident to the new manager ......the compressor motor had shorted windings to earth caused by paint overspray lodging in the cooling ducts ......anyhoo, motor cleaned and rewound ,switchgear replaced ......good as new
Shoreline_
Springfield, MA
Haha good story. The other week a tech was using the top of a 250hp drive as a shelf and he was missing a 1/2-13 washer on a cooler reinstall. Needless to say we found where it went when we threw the breaker and sent a huge explosion to the back of the compressor room. 25k later drive replaced.
MacMcMacmac
canada
I'm not talking about the box. I've seen ground wires sparking when I disconnected them because someone was using ground for a neutral.
signcrafter
I'm not an expert but in my head that doesn't make sense. If the switch is off you still don't have any current flowing to the motor that is causing the issue. Are you saying if there is something drawing current downstream on the load side of that gfi that it could be feeding back into the neutral to the bad motor and if the bad motor neutral and ground are touching somewhere that would trip it?
Maui
Upstate NY
No brushes in that motor.
Those are Emerson-made sleeve bearing motors very similar to this one. @Maui, if you must open that one up, it's very easy.
Frank Lee is right. This motor has no brushes. I've gone through probably close to 100 motors Frank. This one will be nothing for me to open up and test.
Maui
Upstate NY
I have plugged it directly into the GFCI without any other loads on that circuit. I've also plugged it into the GFCI using an extension cord and with other loads attached. The result is always the same. Yes, there is another load normally plugged into that same outlet.
signcrafter
You don't have any outlets that are not gfi protected that you could plug it into and see if it works without the gfi?
American Locomotive
Rhode Island
On your outlet that is tripping, measure the voltage between neutral and ground. I bet you have a neutral-ground bonding issue, causing your neutral voltage to be higher than ground (or vice-versa). Your motor likely has a little leakage. Since youe neutral voltage is different than ground, current will flow and trip the GFCI.
This is the only way that motor could trip the GFCI with the breaker off and everything wired correctly.
Maui
Upstate NY
I'm opening the motor up and doing some basic tests on it before it gets plugged in anywhere else.
Hannahranga
Can draw it out when I'm home but RCDs/GFCI's work on any imbalance, if the neutral has more current flowing on it than the active it'll still trip.
Basically when the neutral/ground get joined (in the faulty motor) it means the current returning from another load on that circuit has another path back to the panel. It goes from the healthy load neutral to the faulty equipment neutral, across the fault to the earth and then back to the neutral at the panel.
