BB70Chevelle
Not really a garage question but hoping some of the members here can help. I have a newer home (2015) the me and the wife turned a spare bedroom into a home gym and im starting to get concerned with how much weight is in that room. Roughly we have about 4000lbs worth of equipment in there. Went in the crawl space last night to get measurements of everything and our house was built using 2x10 floor joist 16" oc. The joist span is 13.5'.
Currently what I'm thinking is to sister all the floor joist and to install a lvl beam under the house. Our frost line here is 12" so I was thinking id go 12"x12"x16" footers? How close can I put a footer to my foundation wall? Can I put a post on one of my foundation footers? Id then use 4x4 post to go from the footer up to a 4"x8"x12' beam. I also plan to add blocking between all the joist for more strength. Last night I measured up and down every joist and none of them have moved at all from the weight so I'm thinking I can just **** the beam up against the floor joist and use straps to tie the floor joist into the new beam?
Anything I should do different? Does my plan sound good?
