stripped grounding screw hole
PoorOwner
CA
almost finished up a weather proof box, all conduit and ears mounted. The last step include putting in the ground wire in one of the holes, the screw is supposed to self tap but it was just hard to turn and the hole has stripped
I put in a pan head steel screw from a plastic anchor but it is sheetmetal/wood threads not machine threads, it is holding a solid Cu Wire against the box interior just fine, I think better than that 10-32 self tap ever was going to be.
Just not sure if I should continue to mess with it with the tapping a bigger hole idea, I know NEC wants like 3 threads of engagement in a sheet metal box, not sure how they have it defined cast aluminum box with a grounding boss on it? The box don't have any threads machined in any of the holes.
The problem with tapping is that the tap don't start to cut threads until about 1/4" (the first little bit does not cut), I did try a 10-32 tap but didn't get very far because of the tap so didn't think drilling for 1/4-20 will be any better, but it may work with a thread restorer that starts to cut right at the end. I don't have the correct drill bit for 1/4-20 anyhow....
So bottom line is was using the non-machine screw OK here? The box itself is connected to EMT so the ground screw is probably not necessary but due to the raintight connector and gaskets etc I wanted to ground the box.
sberry
Brethren, Michigan
Sheet screws in sheet are not allowed and with good reason but in that box I wouldn't lose sleep with a good tight repair. In any of these I spray or drop of oil on a screw when I install.
P
PoorOwner
CA
Thanks
I know the box is grounded in 2 ways and my house not going to burn down by this. Sometimes hard to go by NEC all the way... things like if I keep 6" of all wires I won't be able to close the box.
matt_i
SE Michigan
Be wary of the bottom tap as it doesn't self-align nearly as well as a tapered tap. So its hard to get started, by hand, in a hole without threads as the tap immediately following the pilot drill. It will do the job though. I have seen sliding tap guides for hand taps...
Drill press to hold the tap would be ideal but it sounds like the box is already mounted and wired...
rlitman
Long Island
Be wary of the bottom tap as it doesn't self-align nearly as well as a tapered tap. So its hard to get started, by hand, in a hole without threads as the tap immediately following the pilot drill...
Correct. It isn't for starting the hole. You use your regular tap to start, then switch to the bottom tap once you have a few good turns in.
Also, if you ever break a tap, just grind the end flat, and you have a new bottoming tap.
P
PoorOwner
CA
ground point is at the bottom of the picture, center of the box
sberry
Brethren, Michigan
I fix them with a sheet metal screw like you were going to do. Make sure its tight and move on. As I said before, I spray all the screws that go in to these boxes.
P
PoorOwner
CA
ok gotcha I think was going to move on with my fix, it is tight..
but I got a 13/64" drill bit and 1/4-20 tap.
If I attempt to tap a 1/4-20 do you think the threads will hold torque?
tyme2par4
NH
Personally I would go with a 1/4-28. That will give you more threads in the thin metal.
teamextreme
Lakewood, CO
I would just stick with what you have. Those pre-threaded holes in bell boxes are in crappy cast material that strip out easily and are usually threaded into a hub or stud that doesn't have a lot of material around it to drill out. The jump from 10-24 to 1/4 is pretty big and I doubt you'll have much material left for a solid thread.
rtz
Oklahoma City
I always wondered if code called for one material or the other. Odd they offer both otherwise. But maybe more important if you buy 100 or 1,000 of those covers.
PugetDude
Superstition Mountains, AZ
I've used a small piece of copper wire on stripped holes like that- just drop a 1" long piece of stranded wire in the hole, tighten the ground screw up snug and trim the excess.
P
PoorOwner
CA
Have heard of using toothpick for wood material
That’s a good trick for soft metal.
sberry
Brethren, Michigan
I work on my own a lot, stuff I am going to own a long time. Nothingbtrashes an investment like corroded screws when needing to service something. I make covers for the top on a lot of outdoor and often spritze the inside of those boxes with spray before mounting the devices. It simply keeps humidity from attracting right off the bat. A little silicone across the top seal of a box and some sealer in vertical plugs don't hurt.
Water intrusion wrecks that stuff, promotes corrosion threaded screw or not. A lubed screw makes a little better thread, doesnt let the dross stick. Keeps it from sticking during installation.
We have hundreds or 1000's of bolts, i can tell when removing one been in service if the installer lubed it, even outdoor for decades,,,, sprayed comes apart. When they are tight and dry they are stuck.
Bert_
NW Iowa
It mainly just the weather in my opinion, steel rusts. Brass or stainless screws would be great but I usually put a dab of anti seize and drill a weep hole in the box.
Nothing worse than trying to change an outlet or something after 10 years and all the screws are rusted and break off. Happens with motor terminal boxes too, that's even worse since you talking about an expensive motor. I know of a few with the cover held on by duck tape.
PT Doc
Or you could use a spiral flute tap and the chip will come out the same hole you entered.
