stripped heat shield mounting lug - helicoil?
Vintage Veloce
San Diego
The exhaust on my old dirt bike has a lug that is stripped out. The lug is one of four used to mount a lightweight heat guard.
The lug is 6mm - 1.00 pitch and about 8mm deep.
I'm trying to figure out how to repair it.
*edit: This repair has to leave the exhaust and heat shield looking as they were originally. This is a restoration project.*
I bought a helicoil kit, but actually using it looks to be a problem.
Drilling out the lug is at high risk of drilling through the exhaust if I drill to far. And then the tap won't tap all the way to the bottom of the lug anyway. Even my "bottom" style tap is going to leave at least 3mm of the bottom of the lug untapped. So that would leave me trying to cut down the helicoil insert to 4mm length, or something like that.
It just doesn't seem like that is going to work... am I missing something?
Removing the lug and replacing it seems like a good idea, but again a delicate cutting job on the thin exhaust metal.
I mentioned to a welding friend that maybe I should have the lug's hole welded up in place and re-tap it, but he said the weld material would be very hard, and I would still have the problem of tapping the shallow closed bottom hole.
I find myself now considering filling the hole with some kind of high temperature filler and tapping that. (JB-Weld?) It's an exhaust, so I'm not sure various fillers would really stand up to that. It will see rather heavy vibration.
And again, tapping the shallow closed bottom hold is the problem.
So... any easy ideas I am missing?
V
Vintage Veloce
San Diego
I will add I have considered this idea, but I don't like it:
Have the full perimeter of the lug welded to the exhaust, gas tight. Then intentionally drill through the lug and into the muffler, so that it is easy to tap and helicoil. And them use sealant on the screw when I assemble the heat guard, so the lug/bung will now be sealed.
But this just doesn't seem "right".
Bigblue&Goldie
If you are just going for function stainless steel band clamps or hose clamps works well.
joe_padavano
Northern VA
That boss was threaded before it was welded to the exhaust. If the hose clamp idea doesn't work for you, the next quick and dirty solution is to find a self-tapping bolt that you can use. Next option would be to cut the boss off of the exhaust, repair the threads or replace it, and weld it back on. Finally, consider welding a threaded stud into the boss and use a nut to retain the heat shield.
MattT
Cut a little high then grind the welds down to the pipe.
Or if you can get away with spacing the heat shield further from the pipe welding a nut on top of the existing boss would be the quick and easy fix.
V
Vintage Veloce
San Diego
Joe and Matt,
you may be right: I may have to try and find someone with more cutting and welding of this kind of stuff than I personally have. I'd make a mess of it.
CJM8515
If your going for full resto its probably a better idea to weld it shut, then drill and retap it. Nutserts are about 1/4-1/2" deep.
Kenstone1
Carefully cut of the stock lug with a DREMEL/CUTOFF WHEEL.
Fabricate a new lug to the OEM dimensions.
Clamp/tack/Tig the new lug onto the muffler in the stock location.
The only proper way to do it to remain stock (looking).
not rocket science,
Kevin54
MEMBER EMERITUS
Urbana, Ohio
HeliCoil it. Grind some of the tip off of your drill bit so it won't cut. All you need is a small lead on the drill and a flat bottom to stop you from drilling through. If you have a pointed tap, start the hole with the tap, back it out, grind the tip off of the tap, then finish tapping. Clear out the chips, insert the HeliCoil, BUST THE TANG OFF AND REMOVE, then cut any coils off that is sticking out the top. 30 minute job, tops.
rlitman
Long Island
This! Treat the helicoil drill bit and tap as consumables. The drill bit doesn't need a point, because it's just cutting out the threads. The tap needs a lead-in to start, it needs less and less as you progress inwards.
kerrynzl
Tauranga, New Zealand
Nutserts I see are all way too deep.
Is this on an exhaust pipe or muffler?
If so, you should be able drill right through. The hole will end up with a bolt plugging it anyway .
I would drill it through , then countersink the top slightly and use a countersink nutsert
You can also get "blind" nutserts
rlitman
Long Island
Two problems with a nutsert. The biggest one is grip length. Nutserts only work in a narrow range of grip lengths, with most being made for sheet metal. They will not expand and/or grip properly with this much insertion depth.
Then there's the seal issue. Yes, a blind insert would solve this, but if you use an open one, even the smallest leak will lead to awful freezing up of the bolt.
Jack84
Netherlands
Can you go a step up and make it M8?
Chopping the old lug and welding on a new one is a good idea too.
