stripping old paint
egore
:headscrat Hey guys, Im new here with a question, I put down a epoxy floor about 10 years ago & its starting to chip in a couple of places. I want to repaint again but how do i prep this floor, when i go to scrape chipped area it just keeps chipping up further. when i getit to stop chipping do i etch it somehow with a acid? Thanks for any tips.:thumbup:
IDASHO
Moscow, Idaho
If it keeps coming up if you fool with it, then you had adhesion problems the first time. More than likely, do to moisture, or incomplete prep.
Typically, a chipped epoxy floor is spot patched with opoxy where you have chips and breaks, then a complete fresh coat is applied to the entire floor.
In this case, if you did have adhesion problems, you will probably be best to find a method to completely remove it.
Id contact the manufacturer, to see if they suggest a specific chemical method, or physical method.
snorvet
Northern Illinois
The way the shotblaster ground down my bare floor, I'm pretty sure it would remove all epoxy to the point where you have a good surface to apply new epoxy. I dont think I'd shotblast unless you were removing epoxy from the entire floor.
