My builder installed an entry door and a French door on the side of my garage, and the slab that the doors rest on is slightly sloped from the rear of the garage to the front (as it should be). Due to general incompetence in my opinion, they didn't support the doors' thresholds in any permanent way as now one side of the door rests on the slab and the other side of the door has maybe a 1/4" gap or so under the threshold.
I'm trying to come up with the best way to fill the gap to 1) support the threshold and 2) seal the gap.
My plan right now is to support the threshold with shims every 6" or so and then seal the gap with foam or caulk/sealer.
Does anyone have a more elegant solution for this? e.g. drill and fill into the gap from the top with some sore of epoxy/concrete stuff (after sealing the inside and outside edge with caulk)...
Thanks.
Thanks.
