readhead
Extending the roof would be better. Most containers have wood floors.
It would appear that you have already made up your mind on this so why don't you just do it the way you want to do it and see what happens?Sure I realize I have a lot to consider that's why I'm here having this discussion. I agree a stem wall would be a good solid foundation to work off of but that doesn't mean it's the only way to do it and it certainly isn't the most economical. I have no problem ditching my idea all together but no one is telling me WHY it won't work. Once again "cobbling" wood posts? How is what I explained cobbling wood posts? There's thousands upon thousands of pole barns built in that fashion.
The trusses are made from 4x4 square tubing so I was thinking I could set 6x6 posts like you would a pole barn....
Maybe a dumb question but why would it be any more flimsy than a traditional pole barn? I would think it would even be more rigid than a pole barn being that each truss would be set on a post. ...
It would appear that you haven't read the thread which we have been discussing pros and cons and even alternate options. Just because I was standing behind my original idea because everyone just started screaming stem wall doesn't mean I have made up mind. Obviosuly you have skipped over thr last few posts about using sea containers as part of the build. All I asked was reasoning why it wouldn't work and be structurally sound. If you care to to explain why it wont work then the floor is yours....It would appear that you have already made up your mind on this so why don't you just do it the way you want to do it and see what happens?
I didn't read all the post, but the sounds of it you want to raise it a few feet...here's what I'd do. If you're NOT going to have a concrete floor in it, set some 6x6's where the wall is going to go. Tie all the 6x6's together with some 2x6's Bolted or screwed to the 6x6's. Put a couple layers of 2x6's on top of the 6x6's and bolt/screw them to it. Then set your building bolted/screwed to the 2x6's on top of the 6x6's. Basically put 6x6's down 4 foot or so deep and get them level, then bolt the building down to them to a layer of boards bolted to the tip of them.
If you are going to pour a floor/slab figure out where the wall is going. After it's poured drill for some anchors and install threaded rods up out of it through a wall built with cinder blocks and bolt the building down with the threaded rods.
My barn has a column (pole) at each truss. The columns are 4 ply construction (made from 2x6's) and the trusses are 2 ply construction (they are 3" thick). The outside two ply's of the column continue up both sides of the truss and the entire column / truss sandwich is lagged together with truss lock screws.
So you could do something similar except through bolt the column ply's to the truss.
I would not do the stem wall. Take a look at the following images, should also work for your project. You could even build your own columns.
This is essentially what I based my original idea off of. With my truss being 4x4 tube once I notch that 6x6 down it would slide up into the truss, so basically that be like the middle 2 plys of your column except it's slid up into the truss vs the truss sitting on top of the plys. Then I would sandwich the truss like your outter 2 plys do.
And you could do that, except it won't be nearly as strong as a fabricated multi-ply column nor, will a 6x6 remain as dimensionally stable as the multiply column.
6x6's are notorious for warping, twisting and cracking since they are center cuts. Going with 2 x 6's you can get much stronger and better quality.
Here's a quick model I drew of the assembly...
Ok cool I didn't know that about the difference in columns. That model is awesome, makes me wonder though about how I would do the out side walls with that being 4x4 outside of the column.
I just picked a point and ran with it.
How much overhang is the truss designed for? The curved end of the truss might be out away from the wall farther..
That looks sort of like a Morton Building...
I have read the posts and it is quite obvious what you want to do. It is your building so just do it the way you want.It would appear that you haven't read the thread which we have been discussing pros and cons and even alternate options. Just because I was standing behind my original idea because everyone just started screaming stem wall doesn't mean I have made up mind. Obviosuly you have skipped over thr last few posts about using sea containers as part of the build. All I asked was reasoning why it wouldn't work and be structurally sound. If you care to to explain why it wont work then the floor is yours....
John, the short stub below the curve would be plumb. It isn't an overhang. The original posts would have slipped into them.
For a slab in my area wouldn't I have to do some sort of monolithic pour for a footer or something to prevent that slab from moving and cracking. I'm definately not a concrete guy. I've thought about it just seemed very costly.There are thousands of stick built buildings sitting on slabs with block under the walls.
(I have one in my yard)
No problems with the dreaded "hinge"
At 8 inches per row, 5 rows will give you a 40 inch height increase.
More than you need.
Blocks are 8 inches wide, but can be more, or less, if you want.
A 2x bolted along the top row will give you something to fasten to.
After the slab is dry it would be a 2 day job for a contractor or a week for an after work "side job."
Thanks readhead.
Using the "OP want's to use the trusses for a pole barn" thought, due to the attachment of the posts, I think that joint would be much stronger if the columns tied into the bottom chord and the top chord. Take a sawzall and cut off the end piece flush with the pole.
That being said I am betting the allowable loads for the trusses aren't up to the task...
So you think the trusses aren't acceptable due to the increase in height? I'm just curious to know why they were good when they were made for that building but they wouldn't be good when attached to a stronger column. I know it was mentioned about the increase in height creating more wind load but is there another reason?
