nolimits76
I'm helping a buddy with a lake house project.
No building codes are being enforced!!! Freeze table depth is 20". He desires a concrete slab on grade, 4" thick. Slab is L-shaped. Construction will be modest (frame siding, trusses, etc). He is trying to self-perform as much as possible, and play general contractor for the rest.
Can someone provide a little guidance on the slab?
My initial thoughts was a 1' x 2' perimeter footing. Slab would be 4" thick w/ 12" thickened edges to transition to the footing. Use fill sand under the main slab w/ waterproofing. Is this sufficient? Better ideas?
I am not 100% certain on reinforcing use. I'd say #4 on 12" centers both ways for the main slab, which would allow min. 1.5" clearance from top & bottom. Not sure on slab edge reinforcing sizes/spacing/layout, nor the footing itself. Seems logical to tie it together so using an L bar to connect footing and slab.
