Stubby ratchets 1/4 and 3/8
shockwave
Marietta,ga
I personally have quite a few see styles and personal preferences
Hazet 863k for 1/4 very hard to reach spots and lower torque like dash work
Matco 88t flex for 3/8 use it all the time for Engine work and finsh off with bigger size
BK13
PDX, OR
I kinda want to pick up one of the Wright 3/8" drive in a 1/4" body jobbers...
oldldh
Fairhope, AL
I have a 3/8" Drive GearWrench 120 tooth flexible stubby ratchet...
Part of the four ratchet set...
Worth the $ 95.00 my Wife spent on them...
ihateminimumwage
My Gearwrench 3/8" stubby ratchet became obsolete when I built a Williams 3/8" drive 1/4" body.
And next to a 1/4" Snap-On T72
Bigblue&Goldie
I have a Snappy FK80 that I really like. On low torque fasteners, you can really zip them out! I like that it's short, has low back drag, and is heavy enough that it swings nice and fits well in your hand. I have 1/4" ratchets, but find the handles too small for my taste.
redwrench60
East Tennessee
A feller could just make his own stubby ratchet from one he has laying around. Here's my bobbed Wright 3/8 ratchet bought from the pawn shop junk bin and trimmed down to size.
skruft
I have a Snap-on but I very, very rarely need it. Probably buying a ratchet at the flea market and cutting it off makes good sense.
franzdom
NC
I like the FK80 for 3/8", I use it mostly for caliper pins, I much prefer it to the compact 3/8 in 1/4 body ratchets. I also have the Nepros 90 stubby but I am not as keen on it, super nice but I am not used to having a QR anymore, at least it takes a lot less force than many of the other QR ratchets.
For a tiny 1/4" stubby you can't beat KTC, these are really small!
nicksnothereman
In the Mojave
They should just make one that's extendable. It couldn't be collapsable type but it should just have a threaded end and ship with an extension and a cap (when you don't use the extension).
Am I wrong here? :lol: I'm sure someone makes something like this.
Bigblue&Goldie
I think the 3/8 in a 1/4 body is much better than a stubby 3/8 because of the size. Between that and a thumbwheel, the stubby is completely obsolete.
I disagree, I have both a 3/8" stubby and a 3/8" in a 1/4" body and I still use my stubby on a regular basis. I hardly ever use the thumb wheel, but it still comes in handy. Ratchets are relatively cheap over a lifetime, so I like to have as many different types in my arsenal.
panknuckshovel
Land o Lakes FL
The 36 tooth Williams/Snap-On ratchets are surprisingly smooth, especially after the guts wear in. Brand new they can feel a little clunky, but still much smoother than any Craftsman RP.
BOOM!!!!! I went with the Williams to replace all my Cman RP, Also, if you do the interweb googlebox digging you will find the Williams 36 for less than the Cman RP's.
oldldh
Fairhope, AL
Most un-expensive...
Both can be had for less than $ 30.00 from Home Depot...
Tekton 72 tooth Stubbies!!!
Quick release, too!!!
bob_the_builder
After reading all the comments about 3/8 drive in a 1/4 body I think I would like the purchase a Snap on FCF72. What is the easiest way to convert this ratchet to a comfort grip. If I order a THLF72-20 handle will that fit on the FCF72 ratchet? Or is it better to purchase a THLF72 and a the FCF72 rebuild kit?
Bob
franzdom
NC
Bob, I have done this. You will need to start with the THLF72 and a rebuild kit. I think you will also need the plate, it doesn't come with the kit. I did it by buying two and converting, swapping an fc72 into a t72 and the thlf72 into a 3/8" drive.
winlinmac
USA
They're so cheap and reliable now, I can buy two for $30 on Amazon now. One for the road, and other tucked away for later use. It's one of the only few tools in which I've created an exception in which the past history of the COO doesn't factor. :bowdown:
