stubby wrenches
OutsideMachinist
Norfolk, VA
I can only recall one time where I had to use a stubby wrench and I did what you did. That was 25 years ago. Often you can find a way around although It may not be as easy or convenient.
If you are a professional auto mechanic I can certainly see buying a mid grade set for that odd time it makes your life easier.
One way you could get a lot of force on a stubby is if you hit it with a hammer. Probably an air hammer because you likely could not get a conventional hammer near it. ;)
ssdave
Eastern Oregon
I have Snap-on short combo wrenches. They are quite useful, but not needed a lot. I also have short double box in both Proto and Snap-on. I really like those, and use them a lot more than the combo's. Particularly the non-offset Proto DBE.
As noted several times above, you don't generally use these in high torque situations, so quality may not be as critical. I'd buy any set that you like the fit, design, and finish on. For me, that would be much more important than the brand. Price would then be the deciding final factor. In my case, price wasn't a decision factor, so I bought the ones I liked best which was Snap-on for combo's and a mix of Snap-on and Proto for DBE. I had some SK's and some Indestro and Williams DBE's before I got the Proto, but upgraded them to Proto and Snap-on because I liked them better.
I had a few unmarked full polish import short combo's before I got the SO sets, they were nearly identical in design to the SO, and worked fine. I'd have no hesitation going to an import set if the design, fit, and the finish quality was good and you want to save the money over a more expensive set.
I recently got a brand new Craftsman short set as a freebee with a set of full polish metric wrenches I ordered to see what they were like. They were a POS. Definitely not worth seeking out and buying. I don't recall ever seeing a poorer job of broaching and finishing on a set of wrenches since 1980 era India tools.
woody6904
NW Ohio
SK in the shop, HF in the service truck. Like has been said, don't need em very often but when you need em you need em.
BK13
PDX, OR
I was eyeballing the SKs but was worried that the somewhat portly ends might cause some problems. Sounds like they are good to go, though...
ssdave
Eastern Oregon
Personally, the reason I chose the Snap-on and Proto wrenches I did was the thin box end. That is one of the primary reasons I use them.
I personally would NOT buy any stubby wrenches with a fat box end or a lobster claw open end. Buy for quality of design, not brand.
DFB
Southern VT/Western Mass
Were these Chinese?
BK13
PDX, OR
I've not looked. Does Proto make stubbies?
DFB
I believe they were US origin. The main set was China. So, the made in US is gold rule didn't apply here; the quality was probably a bit worse than the China ones.
Just curious. I was reading comments on the sears page for the stubbys someone two years ago gave feedback saying the picture was for USA but he got China
I haven't bought a Craftsman wrench in at least 15 years now :dunno:
nbpt100
Massachusetts
They were not the EVOLVE Craftsman? I know those are cheap. Like Stanley quality.
Maybe they were factory rejects so they used them as a freebies to help make other sales.
So disappointing to hear they are US origin.
T45
The usa Ignition wrenches are ****. wonder if it was those?
Aqua-Andy
I have a set of SO metrics that I purchased for 60% off while I was in school. I find the stubby wrenches come in very handy. I would never pay full price for the SO or even 60% off for that matter if I had to do it over again. A few years ago when we were doing a lot of brake lines on Silverados I needed a 9/16" as I was done making a 14mm work on the SAE nut size. I purchased a set from Lowes, 3/8-3/4" for under $20 and find them just as good as the SnapOn wrenches. The reality is with a wrench this short you will never get enough leverage on it to spread the jaws.
