Stuck C Clamp...
Jason280
I picked up a semi-rusted Jorgensen 104 4" C Clamp, and the main screw is seized in the collar and won't budge. I've soaked and resoaked it with PB Blaster for the last couple of days, but it still won't budge. I've hit it a few times around the collar with a hammer to "shock it", but still no luck. I'm tempted to tack weld a grade 8 bolt and hit it with an impact, but wanted to get a few suggestions before I get desperate.
Would heat be the best method for freeing it up? I'm trying not to damage it, but I refuse to let it win... ;)
J
Jason280
drewsifer714
Grand Rapids, Ohio
I know it's supposed to be "line of sight" but I've had good luck with electrolysis for stuff like that.
Worked well with a cross slide vise and and an adjustable wrench I found in a yard.
As a side benefit, it takes off any other rust.
But, you shouldn't use electrolysis if it was chromed. Didn't look like it from the picture.
Ive had some crappy clamps with chromed screws over the years.
jumbojak
Surry, VA
Would propane or MAPP be hot enough, or will I have to break out the acetylene?
Propane will probably so the job. Apply heat and then tap on the handle, first one way and then the other. It'll take a while but you'll get it eventually.
jumbojak
Surry, VA
Is it me or does it look bent in? The screw that is
I don't think so. Comparing the pictures from different angles it looks bent one way in one picture and opposite in the other. The swivel cap throws it off, I think.
850xpeps
ATF and acetone mixed spray on it.
Sent from my iPad using Tapatalk Pro
jdoe213
Anderson, SC
Heat where the screw goes through the clamp not the screw.... Right?
Sent from my LG-K425 using Tapatalk
Shadowdog500
Down the shore
If you aren't in a hurry, just give it a "squirt and a jiggle" once or twice a week and it will loosen up in a couple weeks.
You may want to look into getting a bottle of Kroil. It is the best penetrating oil I've ever used.
Chris
matt_i
Kroil will work, just a few more drops every day, use a dental pick or o-ring probe to assist getting it down as far as you can. I had good luck with the paraffin wax too.
The problem with heat is you can get it hot enough to stretch the thread or tweak the shaft out of straightness if you aren't careful when its red hot.
I think you need oxyacet, nothing else will do for that size.
OccupantRJ
Eastern North Carolina
Even a handheld butane torch should do it. Heat up the body of the clamp only for a few minutes, then spray a shot of penetrant in the joint line. This will let the penetrant get to where it needs to be to do the job. Be careful not to breathe the vapors created.
Bondo
Greenfield, Maine
Ayuh,.... Heat the seized area til it starts to change to a reddish color, 'n drop it into a bucket of water,.....
Remove from the water, blow it dry with compressed air, 'n oil it with yer choice of pen-oil,....
By then, it'll screw like a brand new clamp,....
By heatin', Hot, 'n quenchin',....
I've been able to remove exhaust system nuts, 'n studs that are sooo rusted, they don't even look like a nut or stud anymore,.....
JimDon
Get some evaporust at Horrible Freight. Put that in a container with a cover so the stuff doesn't evaporate and dunk your c-clamp for a few days. I have done this numerous times and you don't have to wrestle with a wrench for days on end. When done, dunk any other rusty tools. Cheers,
Jim Don
toolmiser
La Crosse, WI
Time and patience. You need both. Soak it, or electrolysis, give it a day of electrolysis or a week of soaking. You can "tap" it on occasion, but time is your friend. Eventually you will win, don't force it.
dkroth
Rochester, New York
I'm jealous of Jason.
No, not because of that!
I see these threads about stuck vises, clamps, nuts and bolts and I'd like to get my hands dirty fixing them myself. I find it satisfying when I solve a problem like this and the bolt finally starts turning.
J
Jason280
I was able to get it loosened today, just took a little propane heat and some wiggling. Cleaned it up with a wire wheel and oiled it, currently waiting for its first clamping job!
drewsifer714
Grand Rapids, Ohio
Glad you got her going.
But!
I'm disappointed in the rest of you guys.
C'mon now, the garage journal way is to jump to the most complicated way first. The way that might require someone to buy or build more tools. :lol:
DaveOmak
Omak Wa.
Chris
Chris has you covered...
mineallmine
Ontario, Canada
Glad to hear you got it loose. I had a pair I got from a yard sale for a buck each. Came home, heated both with map gas to get them moving then lubed them up and have been using them ever since.
