go with 3/4" melamine. I made one out of this 10+ years ago and its holding up.
That is a possibility, but I have not been able to find it in small pieces either.
Are there any counter top shops around you, they should have a redo or something they took out.
Sent from my SM-A102U using Tapatalk
I found two and one of them has referred me to a tile place that I will check out tomorrow.
The big box stores are open and usually have some small countertop sections available. 4ft piece is like $60 but would leave you little waste.
Any reason you don't buy an existing router table top to build off of? Just a thought, but for me the choice simplified router mounting, raising/lowering through the top, fence adjustment, and it was aluminum so it's pretty flat for my needs and I dont worry about corrosion in my unheated garage. At some point I'm building a workbenches with a table saw and my router table incorporated in to the work surface. Don't get me wrong...I'm all for building from scratch. This just worked easier for me and allowed me to keep my adjustable router base on the table ready to go. YMMV.
V/R
Bogie
I checked Lowes and HD closest to me with no luck. I have since done an online search and found a Lowes across town that is advertising some short countertops. If the tile shop falls through, I will check them out.
I am on a kick to build cabinets to hold key items (planer, belt/disk sander, and router) that will also store other items to free up counter and floor space. For that reason, I wanted to build from wood and I have already acquired T-track and a router mounting plate. Another goal is for clamps and stops, etc that I already have made to be interchangeable between drill press table, table saw sled, and router table.
1/4" tempered hardboard.
A 4x8 sheet is like $15
Price is good, but still leaves me with extra material.
I would think metal would be better. A table saw to me looks like it would be ideal, you'd have the fence guide. I would think you could get one cheap, a bad motor, etc.
Sent from my SM-S320VL using Tapatalk
Good idea, but doesn't meet some of the design goals that I did not include in my original post.
