JasonF
Just finished a 32x48x12 pole building and am doing to wiring now. My initial plan was too put can lights in the eves above the overhead doors, entry door and windows. I then come across these exterior barn lights from Menards, fairly cheap and I thought they would look good centered above all the doors.
http://www.menards.com/main/outdoor...iling-wall-outdoor-light/p-1509827-c-7906.htm
Problem is that the center point of all my doors fall right on a steel rib. What are my options for mounting a fixture over this rib or what do you thing about the light being off-center? I know if I would have pre-planned I could have had a square trim plate put up for a fixture but that needed to go up before the steel.
Heres is a pick of the doors;
My second question is, if I were to go back to putting can lights in, what am I looking for in a can light? When I search through Home Depots sight I dont see anything that say exterior use for instance? I do see some that say for use in damp locations but they still appear to be open enough to let bugs in?
